1. Re: After effects working slowly
imeilfx Mar 14, 2017 10:48 PM (in response to vitor hugop59356062)All depends on how complicated (labor intensive) is your project. AE is a beast that can eat as much as you will give it to it, But please check:
- how much ram AE see your AE(edit/preferences/memory)\- do you have any big images/photos used inyour project
- when you are rendering check how much ram/procesor is being used- do you use ray tracing for any 3D text/layers- do you use any large not compressed video files (and for example have those files on the same hdd that you are rendering/exporting to)
- do you use add to render queue or add to AME render queue for rendering
And the most importtant question - what do you mean buy saying slow - i mean ... how complicated is your project and how much it takes to render?
2. Re: After effects working slowly
vitor hugop59356062 Mar 15, 2017 10:06 AM (in response to imeilfx)Thank you for the reply.
I'm not using any image or video, just shapes. It's going slow when I press to preview and it renders the part selected... I'm waiting around 2 minutes to preview 5 seconds of the clip.
I'll check if it is using the ram at its fullest.
3. Re: After effects working slowly
Szalam Mar 16, 2017 10:48 AM (in response to vitor hugop59356062)Is your composition set to anything other than Classic Renderer?
4. Re: After effects working slowly
Kevin-MonahanApr 14, 2017 3:53 PM (in response to vitor hugop59356062)
Hi VitorHugo,
Did you ever solve this performance issue? Let us know if you still need assistance.
Kevin
