2 Replies Latest reply on Mar 15, 2017 8:36 AM by Szalam
    Scale Expression Help
    jcalverley1
      I'm using Sound Keys. I understand how to picwhip the scale parameter of another layer to the output of the SoundKeys layer but I want it to effect only the Z parameter in the scale, not the whole scale adjustment. Please any help would be greatly appreciated! Thanks
        • 1. Re: Scale Expression Help
          Define the value for z like this:
          z = drag the pickwhip to the Sound Keys parameter you want to use;
          Then set up your array to read the current value for x and y:
          [value[0], value[1], z]
          This is pretty basic expression language. You should spend some time with the expression reference guide if you plan on using expressions.
          I hope that you understand that in order for Z scale to have any effect on the layer you must move the Anchor Point in Z. This will make the layer move in Z space.
          • 2. Re: Scale Expression Help
            The scale (and position and orientation) parameters of 3d layers are arrays of 3 values.
            So, think of it as [scale0, scale1, scale2]
            You just have to point the z value to it and not the x and y.
            Something like [0,0,pickwhippedproperty] +value should do it for you.
            Edit: I see Rick and I were typing at the same time. His would work too.
