I am constantly getting the memory pop up error..
I am using Adobe Creative Cloud
My computer specs
i7 7700k @ 4.5ghz
1070 FTW ACX 3.0
32GB 2400 mhz
ASUS Maximus ix Hero
I should not be having this issue with my computer, so I presume it is my file.
My video file is exported from Premier Pro as sequence setting - MPEG4
Recorded on a T5i
Michael Berg
Project Manager
Exported as QT Animation, video runs fine. As soon as I add keylight 1.2 to pull the green screen, i start getting that error again on playback.
Are we talking MEMORY or STORAGE?
Here's a shot in the dark -- purge your memory & caches and see what happens. If you've run earlier AE versions, get rid of their caches on your cache drive, too.
The error states..
After Effects error: Keylight out of memory. (4) (25 :: 241)
mpeg4. Too bad you can't export something less computationally-intensive from PP.
More diagnostic questions from other folks will follow.
I exported x.264 and same result, but less often.
Mike
H.264 is still crummy. Think quicktime movies in JPEG 2000, Photo JPEG, ProRes 422 or PNG codecs. They work best.
Alright, I will try another format and reply with results.
Mike
If it doesn't work, you've got other issues and you may want to create a new post.
You have other issues, and I'm a lousy diagnostician -- I have people who solve my software woes.
I recommend starting a new thread, describing BOTH the problem and the remedial steps you've taken. They'll want PRECISE version numbers for OS & CC, so come prepared.
Thanks for all your help. Where should I start a new thread? Is there a different location in the forums I should be going?
Mike
Nope -- just post the way you did when you started this thread. Works like a charm.
