4 Replies Latest reply on Jan 16, 2018 7:24 AM by sabar80419073
    Error Build Android - java error: incompatible types: File[] cannot be converted to File   File files = directory.listFiles();
    carloss63981566
      Build Date: 2017-03-15 17:16:16 +0000
      PLUGIN OUTPUT
      Fetching plugin "com.peerio.cordova.plugin.sqlcipher@1.2.2" via npm
      Installing "com.peerio.cordova.plugin.sqlcipher" at "1.2.2" for android
      Fetching plugin "cordova-plugin-whitelist@1.3.2" via npm
      Installing "cordova-plugin-whitelist" at "1.3.2" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      Fetching plugin "cordova-plugin-splashscreen@4.0.2" via npm
      Installing "cordova-plugin-splashscreen" at "4.0.2" for android
      Installing "com.phonegap.plugins.hydration" at "6.2.0" for android
      Installing "cordova-plugin-network-information" at "1.0.1" for android
      Dependent plugin "cordova-plugin-whitelist" already installed on android.
      Fetching plugin "phonegap-plugin-contentsync" via npm
      Installing "phonegap-plugin-contentsync" at "1.3.4" for android
      COMPILE OUTPUT
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugResources
      :processDebugResourcesWarning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      /project/src/com/adobe/phonegap/contentsync/Sync.java:1123: error: incompatible types: File[] cannot be converted to File
      /project/src/com/adobe/phonegap/contentsync/Sync.java:1125: error: for-each not applicable to expression type
        for (File file : files) {
        required: array or java.lang.Iterable
        found: File
      Note: /project/src/com/adobe/phonegap/contentsync/Sync.java uses unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      2 errors
      FAILURE: Build failed with an exception.
      :compileDebugJavaWithJavac FAILED
      * What went wrong:
      Execution failed for task ':compileDebugJavaWithJavac'.
      > Compilation failed; see the compiler error output for details.
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 2.166 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
        found: File
      2 errors
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
