2 Replies Latest reply on Mar 23, 2017 11:39 AM by geordiem74078114
    Placing/moving clips in a sequence at sub-frame accuracy
    Rambutan Level 1
      Hi all, anyone got a workaround using supported or unsupported APIs to place or move a clip in a sequence using seconds or ticks instead of timecode?  Working with audio files and need to place items very accurately on the timeline.
      1st try: Got clip placement working but can only give times in TC ie snapped to frames
      2nd try:  Can set the CTI using ticks which is great, can omit a start time when placing a clip which uses the current CTI, BUT the placed clip time still snaps to frames .
      3rd try: Call a Powershell script which "presses" the "," key which accurately inserts a clip to the current CTI, but can't change the track targeting programmatically so has limited use besides the obvious hackz.
      PS: This is all while "Show Audio Time Units" is active for the sequence.
      PPS: I've tried the alignToVideo = false option of the insert function and doesn't  seem to do anything
      Any help is appreciated.
      TNKS!
      G
