4 Replies Latest reply on Jun 2, 2017 6:15 AM by xanda escuyer
    CANNOT WRITE FILES (PDF) ON microSD CARD SAMSUNG TABLET
    ricky.ser
      I own a SM-T580, Galaxy TAB A6 10.1, it's great, but unfortunately with Android 6.0.1 (and several other systems), Google made a change to the way SD cards are handled, and now apps have a very limited ability to store data on the SD card. For instance, when I open a PDF file (stored on the SD card) with Adobe Acrobat Reader, it says "This document is read-only, so changes cannot be saved. Would you like to create a local copy on your device to continue editing?". This is frustating, what's the point in being able to adopt a very large SD card when you can't use it?
      With older systems, an app called SDfix would work to fix the issue, but that requires root access. Also, in newer systems like Marshmallow 6.0.1, the SDfix app does not work because newer systems don't have the line "WRITE_EXTERNAL_STORAGE" in the file /system/etc/permissions/platform.xml that would be modified by the app to allow writing permission to SD cards. Adobe Reader has storage permission to "modify or delete the contents of your SD card", but that does not matter. I cannot even choose to use my microSD card as internal storage, my Samsung tablet does not allow this option. I just want to be able to work with PDF files in my SD card and to be able to save them there. If anybody had any suggestions on the subject they would be much appreciated!!!
