1 Reply Latest reply on Mar 16, 2017 6:44 AM by Szalam
    How can we get currentPage url into Datasource
    satishkumark53044762 Level 1
      Below is datasource.jsp for adding dynamic dropdown into my customComponent dialog, I'm using this datasource in my customComponent as below mentioned <dataSourceTest> field.
      Here my requirement is need to get url values to dropdown when my customComponent used in any page(this page having urls). So here i need that currentPage url where i have used my customComponent.
      Please help me to get that page url where i have used my customComponent to this datasource.
      request.setAttribute(DataSource.class.getName(), EmptyDataSource.instance());
      ResourceResolver resolver = resource.getResourceResolver();
      //Create an ArrayList to hold data
      List<Resource> fakeResourceList = new ArrayList<Resource>();
      ValueMap vm = null;
      Resource childResource = resourceResolver.getResource(currentPage.getPath()+"/jcr:content/node/path");
      if(childResource!=null){
          Node childNode = childResource.adaptTo(Node.class);
          Node childLinks = childNode.getNode("childnode");
           if(childLinks!=null){
          NodeIterator childrenNodes = childLinks.getNodes();
                while(childrenNodes.hasNext()) {
                   vm = new ValueMapDecorator(new HashMap<String, Object>());
                   Node next = childrenNodes.nextNode();
                   String label = next.getProperty("label").getValue().getString();
                   String path = next.getProperty("url").getValue().getString();
                   vm.put("text",label);
                   vm.put("value",path.substring(1));
                   fakeResourceList.add(new ValueMapResource(resolver, new ResourceMetadata(), "nt:unstructured", vm));
      } else {
          vm.put("text","NoValue");
          vm.put("value","");
      DataSource ds = new SimpleDataSource(anchorResourceList.iterator());
      request.setAttribute(DataSource.class.getName(), ds);
      customComponent dialog content.xml which is using above datasource as it's sling:resourceType.
      <dataSourceTest
           jcr:primaryType="nt:unstructured"
           sling:resourceType="granite/ui/components/foundation/form/select"
           fieldDescription="Provide a unique ID to support deeplinking"
           fieldLabel="Anchor"
           name="./datasourceTest">
           <datasource
                sling:resourceType="/apps/nvidiaGDC/components/page/datasource"/>
      </dataSourceTest>
      [Moved from Forum comments to AEM forum - moderator]
