12 Replies Latest reply on Mar 21, 2017 5:45 PM by DaveMcKeen
    Photoshop 2017.0.1 Crashes on Printing
    DaveMcKeen Level 1
      Hello!  I am using Windows7 Pro, 64 bit and Photoshop CC versions 2015.5 and 2017.0.1
      I had an Epson Artisan 50 printer die on me recently and replaced it with an Epson Expression Photo XP-960.  I also have a Brother HL-2270DW laser printer with an Ethernet connection.  When I replaced the inkjet printers I set the now one up with a USB connection and made the Brother the default printer.
      I have some PSD files for printing on Neato CD label media.  Since swapping out the inkjet printers, Photoshop crashes when I try to send certain of these files to print.  I mean crashes without a whimper.  I never see the Print dialog.  I get a Windows info box that says Photoshop stopped working.
      I was using Photoshop CC 2015.5 when this started happening.  This gave me incentive to go ahead and install CC 2017.  I installed 2017.0.1.  When I tried sending the same files to print, the same thing happened.
      The Photoshop Help>System Info file is enclosed. Also enclosed is a Windows Reliability Monitor screen shot with a record of the crashes.  (No provision for attachments?)
      I managed a workaround by copying layers from a problem PSD file to a similar one that did not cause a crash and renamed the resulting file.
      Other Photoshop files print fine, as do print jobs from other applications.
      Questions:
      1. 1. How can I determine why Photoshop crashes?
      1. 2. How to remove print information from a problem PSD file?
      Thanks very much, - Dave
      Adobe Photoshop Version: 2017.0.1 20161130.r.29 2016/11/30:23:00:00 CL 1099099  x64
      Number of Launches: 2
      Version: 7 SP1
      System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
      Physical processor count: 4
      Logical processor count: 8
      Processor speed: 4000 MHz
      Built-in memory: 32709 MB
      Free memory: 2 MB
      Memory available to Photoshop: 29568 MB
      Memory used by Photoshop: 60 %
      History Thumbnails: Enabled.
      Touch Bar: Enabled.
      Alias Layers: Disabled.
      Modifier Palette: Disabled.
      3D Multitone Printing: Disabled.
      Highbeam: Enabled.
      Image tile size: 1024K
      Image cache levels: 4
      Font Preview: Medium
      TextComposer: Latin
      Display: 1
      Display Bounds: top=0, left=0, bottom=1200, right=1920
      OpenGL Drawing: Enabled.
      OpenGL Allow Old GPUs: Not Detected.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      AIFCoreInitialized=1
      AIFOGLInitialized=1
      OGLContextCreated=1
      NumGLGPUs=1
      NumCLGPUs=1
      NumNativeGPUs=0
      glgpu[0].GLVersion="4.1"
      glgpu[0].IsIntegratedGLGPU=0
      glgpu[0].GLMemoryMB=2048
      glgpu[0].GLName="NVIDIA GeForce GTX 760"
      glgpu[0].GLVendor="NVIDIA Corporation"
      glgpu[0].GLVendorID=4318
      glgpu[0].GLDriverVersion="9.18.13.4752"
      glgpu[0].GLRectTextureSize=16384
      glgpu[0].GLRenderer="GeForce GTX 760/PCIe/SSE2"
      glgpu[0].GLRendererID=4487
      glgpu[0].HasGLNPOTSupport=1
      glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
      glgpu[0].GLDriverDate="20150205000000.000000-000"
      glgpu[0].CanCompileProgramGLSL=1
      glgpu[0].GLFrameBufferOK=1
      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
      glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
      clgpu[0].CLPlatformVersion="1.1"
      clgpu[0].CLDeviceVersion="1.1 CUDA"
      clgpu[0].IsIntegratedCLGPU=0
      clgpu[0].CLMemoryMB=2048
      clgpu[0].CLName="GeForce GTX 760"
      clgpu[0].CLVendor="NVIDIA Corporation"
      clgpu[0].CLVendorID=4318
      clgpu[0].CLDriverVersion="347.52"
      clgpu[0].CLBandwidth=1.49227e+11
      clgpu[0].CLCompute=644.88
      License Type: Subscription
      Serial number: 96040971213733443043
      GUIDBucket:
        bucket: 51
        test: control
      Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
      Temporary file path: C:\Users\dmckeen\AppData\Local\Temp\
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Startup, 238.4G, 135.0G free
      Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\
      Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
      Installed components:
         A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
         ACE.dll   ACE 2016/11/04-01:10:53   79.578171   79.578171
         AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
         AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
         AdobeOwl.dll   Adobe Owl   5.2.11
         AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
         AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
         AdobeSVGAGM.dll   AdobeSVGAGM   79.578171   79.578171
         AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
         AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
         AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
         adobe_caps.dll   Adobe CAPS   10,0,0,6
         AGM.dll   AGM 2016/11/04-01:10:53   79.578171   79.578171
         ahclient.dll    AdobeHelp Dynamic Link Library   2.0.0.2
         AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
         amtlib.dll   AMTLib (64 Bit)   10.0.0.47 BuildVersion: 10.0; BuildDate: Thu Sep 1 2016 5:16:17)   1.000000
         ARE.dll   ARE 2016/11/04-01:10:53   79.578171   79.578171
         AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
         AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
         Bib.dll   BIB 2016/11/04-01:10:53   79.578171   79.578171
         BIBUtils.dll   BIBUtils 2016/11/04-01:10:53   79.578171   79.578171
         boost_date_time.dll   photoshopdva   10.0.0
         boost_signals.dll   photoshopdva   10.0.0
         boost_system.dll   photoshopdva   10.0.0
         boost_threads.dll   photoshopdva   10.0.0
         cg.dll   NVIDIA Cg Runtime   3.0.00007
         cgGL.dll   NVIDIA Cg Runtime   3.0.00007
         CIT.dll   Adobe CIT   2.1.0.1   2.1.0.1
         CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
         CoolType.dll   CoolType 2016/11/04-01:10:53   79.578171   79.578171
         dnssd.dll   Bonjour   3,0,0,2
         dvaaudiodevice.dll   photoshopdva   10.0.0
         dvacore.dll   photoshopdva   10.0.0
         dvamarshal.dll   photoshopdva   10.0.0
         dvamediatypes.dll   photoshopdva   10.0.0
         dvametadata.dll   photoshopdva   10.0.0
         dvametadataapi.dll   photoshopdva   10.0.0
         dvametadataui.dll   photoshopdva   10.0.0
         dvaplayer.dll   photoshopdva   10.0.0
         dvatransport.dll   photoshopdva   10.0.0
         dvaui.dll   photoshopdva   10.0.0
         dvaunittesting.dll   photoshopdva   10.0.0
         dynamiclink.dll   photoshopdva   10.0.0
         ExtendScript.dll   ExtendScript 2016/01/26-16:09:33   80.1060872   80.1060872
         icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
         icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
         icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
         igestep30.dll   IGES Reader   9.3.0.113
         imslib.dll   IMSLib DLL   10.0.0.1
         JP2KLib.dll   JP2KLib 2016/05/26-01:08:58   79.262945   79.262945
         libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
         libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
         libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
         LogSession.dll   LogSession   7.4.1.60.45263
         mediacoreif.dll   photoshopdva   10.0.0
         MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
         pdfsettings.dll   Adobe PDFSettings   1.04
         Photoshop.dll   Adobe Photoshop CC 2017   18.0.1
         Plugin.dll   Adobe Photoshop CC 2017   18.0.1
         PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
         PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
         PSArt.dll   Adobe Photoshop CC 2017   18.0.1
         PSViews.dll   Adobe Photoshop CC 2017   18.0.1
         SCCore.dll   ScCore 2016/01/26-16:09:33   80.1060872   80.1060872
         SVGRE.dll   SVGRE   79.578171   79.578171
         svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
         tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
         tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
         TfFontMgr.dll   FontMgr   9.3.0.113
         TfKernel.dll   Kernel   9.3.0.113
         TFKGEOM.dll   Kernel Geom   9.3.0.113
         TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
         updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
         VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
         VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
         WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
         wu3d.dll   U3D Writer   9.3.0.113
      Required plug-ins:
         3D Studio 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         Accented Edges 18.0.1 - from the file “Filter Gallery.8bf”
         Adaptive Wide Angle 18.0.1 - from the file “Adaptive Wide Angle.8bf”
         Angled Strokes 18.0.1 - from the file “Filter Gallery.8bf”
         Average 18.0.1 (2017.0.1 x001 x003) - from the file “Average.8bf”
         Bas Relief 18.0.1 - from the file “Filter Gallery.8bf”
         BMP 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Camera Raw 9.9 - from the file “Camera Raw.8bi”
         Camera Raw Filter 9.9 - from the file “Camera Raw.8bi”
         Chalk && Charcoal 18.0.1 - from the file “Filter Gallery.8bf”
         Chrome 18.0.1 - from the file “Filter Gallery.8bf”
         Cineon 18.0.1 (2017.0.1 x001 x003) - from the file “Cineon.8bi”
         Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds.8bf”
         Collada 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         Color Halftone 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Colored Pencil 18.0.1 - from the file “Filter Gallery.8bf”
         CompuServe GIF 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Conté Crayon 18.0.1 - from the file “Filter Gallery.8bf”
         Craquelure 18.0.1 - from the file “Filter Gallery.8bf”
         Crop and Straighten Photos 18.0.1 (2017.0.1 x001 x003) - from the file “CropPhotosAuto.8li”
         Crop and Straighten Photos Filter 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Crosshatch 18.0.1 - from the file “Filter Gallery.8bf”
         Crystallize 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Cutout 18.0.1 - from the file “Filter Gallery.8bf”
         Dark Strokes 18.0.1 - from the file “Filter Gallery.8bf”
         De-Interlace 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Dicom 18.0.1 - from the file “Dicom.8bi”
         Difference Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds.8bf”
         Diffuse Glow 18.0.1 - from the file “Filter Gallery.8bf”
         Displace 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Dry Brush 18.0.1 - from the file “Filter Gallery.8bf”
         Eazel Acquire 18.0.1 (2017.0.1 x001 x003) - from the file “EazelAcquire.8ba”
         Entropy 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         Export Color Lookup Tables NO VERSION - from the file “Export3DLUT.8be”
         Extrude 18.0.1 - from the file “Standard MultiPlugin.8bf”
         FastCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “FastCore.8bx”
         Fibers 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Film Grain 18.0.1 - from the file “Filter Gallery.8bf”
         Filter Gallery 18.0.1 - from the file “Filter Gallery.8bf”
         Flash 3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         Fresco 18.0.1 - from the file “Filter Gallery.8bf”
         Glass 18.0.1 - from the file “Filter Gallery.8bf”
         Glowing Edges 18.0.1 - from the file “Filter Gallery.8bf”
         Google Earth 4 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         Graphic Pen 18.0.1 - from the file “Filter Gallery.8bf”
         Halftone Pattern 18.0.1 - from the file “Filter Gallery.8bf”
         HDRMergeUI 18.0.1 - from the file “HDRMergeUI.8bf”
         HSB/HSL 18.0.1 - from the file “Standard MultiPlugin.8bf”
         IFF Format 18.0.1 - from the file “Standard MultiPlugin.8bf”
         IGES 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         Ink Outlines 18.0.1 - from the file “Filter Gallery.8bf”
         JPEG 2000 18.0.1 - from the file “JPEG2000.8bi”
         Kurtosis 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         Lens Blur 18.0.1 - from the file “Lens Blur.8bf”
         Lens Correction 18.0.1 - from the file “Lens Correction.8bf”
         Lens Flare 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Liquify 18.0.1 - from the file “Liquify.8bf”
         Matlab Operation 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort.8bf”
         Maximum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         Mean 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         Measurement Core 18.0.1 (2017.0.1 x001 x003) - from the file “MeasurementCore.8me”
         Median 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         Mezzotint 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Minimum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         MMXCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “MMXCore.8bx”
         Mosaic Tiles 18.0.1 - from the file “Filter Gallery.8bf”
         Multiprocessor Support 18.0.1 (2017.0.1 x001 x003) - from the file “MultiProcessor Support.8bx”
         Neon Glow 18.0.1 - from the file “Filter Gallery.8bf”
         Note Paper 18.0.1 - from the file “Filter Gallery.8bf”
         NTSC Colors 18.0.1 (2017.0.1 x001 x003) - from the file “NTSC Colors.8bf”
         Ocean Ripple 18.0.1 - from the file “Filter Gallery.8bf”
         OpenEXR 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Paint Daubs 18.0.1 - from the file “Filter Gallery.8bf”
         Palette Knife 18.0.1 - from the file “Filter Gallery.8bf”
         Patchwork 18.0.1 - from the file “Filter Gallery.8bf”
         Paths to Illustrator 18.0.1 - from the file “Standard MultiPlugin.8bf”
         PCX 18.0.1 (2017.0.1 x001 x003) - from the file “PCX.8bi”
         Photocopy 18.0.1 - from the file “Filter Gallery.8bf”
         Photoshop 3D Engine 18.0.1 (2017.0.1 x001 x003) - from the file “Photoshop3DEngine.8bi”
         Photoshop Touch 14.0 - from the file “PSDX.8bi”
         Picture Package Filter 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort.8bf”
         Pinch 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Pixar 18.0.1 (2017.0.1 x001 x003) - from the file “Pixar.8bi”
         Plaster 18.0.1 - from the file “Filter Gallery.8bf”
         Plastic Wrap 18.0.1 - from the file “Filter Gallery.8bf”
         PLY 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         PNG 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Pointillize 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Polar Coordinates 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Portable Bit Map 18.0.1 (2017.0.1 x001 x003) - from the file “PBM.8bi”
         Poster Edges 18.0.1 - from the file “Filter Gallery.8bf”
         PRC 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         Radial Blur 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Radiance 18.0.1 (2017.0.1 x001 x003) - from the file “Radiance.8bi”
         Range 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         Render Color Lookup Grid NO VERSION - from the file “Export3DLUT.8be”
         Reticulation 18.0.1 - from the file “Filter Gallery.8bf”
         Ripple 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Rough Pastels 18.0.1 - from the file “Filter Gallery.8bf”
         Save for Web 18.0.1 - from the file “Save for Web.8be”
         ScriptingSupport 18.0.1 - from the file “ScriptingSupport.8li”
         Shake Reduction 18.0.1 - from the file “Shake Reduction.8bf”
         Shear 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Skewness 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         Smart Blur 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Smudge Stick 18.0.1 - from the file “Filter Gallery.8bf”
         Solarize 18.0.1 (2017.0.1 x001 x003) - from the file “Solarize.8bf”
         Spaces 18.0.1 - from the file “Spaces.8li”
         Spatter 18.0.1 - from the file “Filter Gallery.8bf”
         Spherize 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Sponge 18.0.1 - from the file “Filter Gallery.8bf”
         Sprayed Strokes 18.0.1 - from the file “Filter Gallery.8bf”
         Stained Glass 18.0.1 - from the file “Filter Gallery.8bf”
         Stamp 18.0.1 - from the file “Filter Gallery.8bf”
         Standard Deviation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         STL 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         Sumi-e 18.0.1 - from the file “Filter Gallery.8bf”
         Summation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         Targa 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Texturizer 18.0.1 - from the file “Filter Gallery.8bf”
         Tiles 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Torn Edges 18.0.1 - from the file “Filter Gallery.8bf”
         Twirl 18.0.1 - from the file “Standard MultiPlugin.8bf”
         U3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         Underpainting 18.0.1 - from the file “Filter Gallery.8bf”
         Vanishing Point 18.0.1 - from the file “VanishingPoint.8bf”
         Variance 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
         Virtual Reality Modeling Language | VRML 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         Water Paper 18.0.1 - from the file “Filter Gallery.8bf”
         Watercolor 18.0.1 - from the file “Filter Gallery.8bf”
         Wave 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Wavefront|OBJ 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
         WIA Support 18.0.1 (2017.0.1 x001 x003) - from the file “WIASupport.8li”
         Wind 18.0.1 - from the file “Standard MultiPlugin.8bf”
         Wireless Bitmap 18.0.1 (2017.0.1 x001 x003) - from the file “WBMP.8bi”
         ZigZag 18.0.1 - from the file “Standard MultiPlugin.8bf”
      Optional and third party plug-ins: NONE
      Duplicate and Disabled plug-ins: NONE
      Plug-ins that failed to load: NONE
      Extensions: NONE
      Installed TWAIN devices: NONE
