4 Replies Latest reply on Mar 20, 2017 11:27 AM by michellem38434587
    Custom calculation script - need help
    michellem38434587
      I have 6 fields with property value and 6 related % Ownership, then a grand total field.  My intent is to take property_1 x ownership = value, do the same for the remaining 5 properties, then add all resulting values for a total property value based on % of ownership.  I first entered script below with only one property (without the surrounding ()'s, and it worked fine, then I added the (), copy/pasted the same script & updated the names.  When I inserted the remaining properties, it doesn't work.   (Note, in the example below the calc would be $300,000 X 59% = $177,000).  Where did I mess up on the script?
      Thank you so much ~ Michelle
      event.value = ( this.getField("MarketValue").value * this.getField("Ownership").value ) + ( this.getField("MarketValue_2").value * this.getField("Ownership_2").value ) + ( this.getField("MarketValue_3").value * this.getField("Ownership_3").value ) + ( this.getField("MarketValue_4").value * this.getField("Ownership_4").value ) + ( this.getField("MarketValue_5").value * this.getField("Ownership_5").value ) + ( this.getField("MarketValue_6").value * this.getField("Ownership_6").value );
        • 1. Re: Custom calculation script - need help
          The script itself doesn't have any errors in it. What do you mean by "it's not working"? Are you getting any error messages in the JS Console? Does it not produce the correct result?
          • 2. Re: Custom calculation script - need help
            michellem38434587 Level 1
            Thank you for your time!
            It does not produce the result I expected.
            1     300,000X59% = 177,000
            2     300,000X100% = 300,000
            3     300,000X100% = 300,000
            4     300,000X100% = 300,000
            5     300,000X100% = 300,000
            6     300,000X100% = 300,000
            When I only had the first property in the query, it returned a result of 177,000 which is correct answer.  When I added in the next 5 (as shown in my original question), I expected to get a result of 1,677,000.  However, the field did not update.    Is there a better way to write the script? Maybe like a weighted value like in Excel?
            I'm still new at this and haven't used the debugger before.  I had to activate it, but don't know if its telling me anything
            • 3. Re: Custom calculation script - need help
              Did you change the value of any of the fields after applying the new code? It won't "kick in" until you do...
              • 4. Re: Custom calculation script - need help
                Thank you for your help.  I tried adding in each section of the query one at a time and it all worked, until I added in property #3.  Not sure how to read the debugger, but it also pointed to #3.  After close review, I found that I had a space in field name between Market and Value, which was different than the rest of the fields.  Fixed that and it worked.  What I learned is to used the debugger to guide me.  thank you soooooo much!
