14 Replies Latest reply on Mar 19, 2017 11:14 AM by Michael Witherell
    continuous footnotes
    thaero17058
      Hello
      How can we add equal sign ( = ) at end of the first page of a continuous footnotes and at the beginning of the second page of continuous footnotes .
      and how can we automate this .
      Example :
      Can you help me please .
        • 1. Re: continuous footnotes
          Michael Witherell Adobe Community Professional
          Several questions come to mind:
          Why do this?  It is highly non-standard.
          What version of InDesign are you using? What OS?
          • 2. Re: continuous footnotes
            thaero17058 Level 1
            because of client
            CS6
            windows 10
            • 3. Re: continuous footnotes
              On the one hand, it isn't done that way, but a paying client can be persuasive, I do realize!
              Further, InDesign does not have a capacity for this.
              It might be scriptable, but I rather doubt it. What the InDesign Scripting community comes up with often amazes me, tho.
              • 4. Re: continuous footnotes
                thaero17058 Level 1
                • 5. Re: continuous footnotes
                  Obi-wan Kenobi Adobe Community Professional
                  Join the Rebellion! … If needed, light-saber hit again (layout changes)!
                      0127_TwoPagesFootnote_MichelAllio.jsx
                      Script written by Michel Allio [2017/03/18]
                  app.doScript("main()", ScriptLanguage.javascript, undefined, UndoModes.ENTIRE_SCRIPT, "2-Pages Footnote! …");
                  function main()
                          myDoc.conditionalTextPreferences.showConditionIndicators = ConditionIndicatorMode.HIDE_INDICATORS;
                          // TO BE MODIFIED! --------------------------------------------------------------------------------------------------------------
                          var myFootnotePStyle = myDoc.paragraphStyles.item("Footnote"),
                          myTracking = -10,  myHorizontalScale = 99;
                          // CREATED BY SCRIPT! -----------------------------------------------------------------------------------------------------------
                          if (!myDoc.conditions.item("2-pages_Footnote").isValid) myDoc.conditions.add ({name: "2-pages_Footnote", indicatorMethod: ConditionIndicatorMethod.USE_HIGHLIGHT, indicatorColor: [255,255,255]});
                          var myCondition = "2-pages_Footnote";
                          app.findGrepPreferences = app.changeGrepPreferences = null;
                          app.findGrepPreferences.appliedConditions = [myCondition];
                          myDoc.changeGrep();
                          app.findGrepPreferences.appliedParagraphStyle = myFootnotePStyle;
                          myFound = myDoc.findGrep();
                          var F = myFound.length;
                          for (var f = 0; f < F; f++) {
                              var myLines = myFound[f].lines,
                              L = myLines.length;
                              for (var l = 1; l < L; l++) {
                                  var myLine = myLines[l];
                                  if ( myLines[l-1].characters[-1].parentTextFrames[0].parentPage !== myLines[l].characters[0].parentTextFrames[0].parentPage ) {
                                      var myLine0 = myLines[l-1],
                                      myLine1 = myLines[l];
                                      myLines[l-1].characters[-1].contents = "\u2002= =\u2002";
                                      myLine0.tracking = myLine1.tracking = myTracking;
                                      myLine0.horizontalScale = myLine1.horizontalScale = myHorizontalScale;
                          app.findGrepPreferences.findWhat = "~>= =~>";
                          app.changeGrepPreferences.appliedConditions = [myCondition];
                          myDoc.changeGrep();
                  • 6. Re: continuous footnotes
                    Hi Obi-wan,
                    your script will not work as expected, if the two == are a substitute for a hyphen.
                    I already asked this here in the InDesign scripting forum:
                    Before running your script:
                    After running:
                    You see, that a character is missing.
                    That would also be the case after re-running the script on non-hyphenation situations after the text were edited so that the two = moved away.
                    I would do it with a different concept in mind:
                    Do not change the text of a footnote, instead add the two = with some extra text frames that cover a potential hyphen also using text wrap to give room to the new two characters.
                    Just to give you an idea without scripting anything:
                    Before:
                    After:
                    Changing the view:
                    Regards,
                    Uwe
                    • 7. Re: continuous footnotes
                      Uwe,
                      i don't really know if the op talk us about an hyphenation sustitute!
                      If the case, maybe a way would be to avoid hyphenation between the two parts of the footnote!  ;-)
                      • 8. Re: continuous footnotes
                        In my script approach, I've forgotten to reset the tracking/horizontal scaling at the beginning of the script!
                        Maybe a better way to treat this point would be using the insertion of 2 non-joiners associated to 2 grep styles! ;-)
                        On this point, I've a question for you: i've no problem to check a condition or a char style (to create them if they don't exist yet in the doc), but how could I check a nested grep style? Add one is easy but verify if it exist? Thanks!
                        • 9. Re: continuous footnotes
                          https://forums.adobe.com/people/Obi-wan+Kenobi  wrote
                          … On this point, I've a question for you: i've no problem to check a condition or a char style (to create them if they don't exist yet in the doc), but how could I check a nested grep style? Add one is easy but verify if it exist? Thanks!
                          That would be a perfect question for the InDesign Scripting forum :-)
                          Regards,
                          Uwe
                          • 10. Re: continuous footnotes
                            Yeap! Going to post it!  =D
                            • 11. Re: continuous footnotes
                              Uwe,
                              I confirm about this point:
                              Uncheck the "Césure sur la colonne" radio button!
                              I think the op only wants to show to the reader a footnote jumps on 2 pages!
                              • 12. Re: continuous footnotes
                                … I think the op only wants to show to the reader a footnote jumps on 2 pages!…
                                Then I'd perhaps do it at the end of a paragraph or a line where the text ends with a sentence.
                                If you think of a scripted solution, do not forget about a situation where a footnote jumps from one column to another one on the same page.
                                Regards,
                                Uwe
                                • 13. Re: continuous footnotes
                                  … More and more complex!
                                  Including a "page" check!
                                  • 14. Re: continuous footnotes
                                    I adore you guys for the scripting magic, but I wish you wouldn't enable the OP to make something that looks like this!
