1. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
c.pfaffenbichler Mar 17, 2017 1:39 AM (in response to matibuc4eva)Use the Offset Filter to get the »seams« to the center of the page’s height and width, then touch them up.
The resulting image should work as the basis of a Pattern (Edit > Define Pattern).
2. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
matibuc4eva Mar 17, 2017 4:46 AM (in response to c.pfaffenbichler) -
3. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
c.pfaffenbichler Mar 17, 2017 5:19 AM (in response to matibuc4eva)Your original screenshot showed a vertical line …
Basically you can still
• start with a »vertical«, square Pattern
• create a Pattern Fill Layer that is at least twice the size of the Pattern tile
• convert it to a Smart Object
• rotate it 45˚
• select a square area of 141.4% the size of the original tile and define a new Pattern
4. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
c.pfaffenbichler Mar 17, 2017 5:41 AM (in response to matibuc4eva) -
5. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
matibuc4eva Mar 17, 2017 6:04 AM (in response to c.pfaffenbichler)Sorry man be patient but i wouldn't know how to how to create a square selection starting exactli from the ceneter and 141,4 % ?
6. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
c.pfaffenbichler Mar 17, 2017 6:08 AM (in response to matibuc4eva)You can store the Selection used to define the first Pattern as an alpha Channel, load that later on and use Select > Transform Selection to increase it to the intended percentage by entering the values in the Options Bar.
7. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
matibuc4eva Mar 17, 2017 6:46 AM (in response to c.pfaffenbichler)I don't know how to save a selection to the alpha channels
8. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
c.pfaffenbichler Mar 17, 2017 6:52 AM (in response to matibuc4eva)Hit the »Save selection as channel«-button in the Channels Panel.
9. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
matibuc4eva Mar 17, 2017 7:13 AM (in response to c.pfaffenbichler) -
10. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
matibuc4eva Mar 17, 2017 7:16 AM (in response to matibuc4eva)could you create a clip of the procedure.i'm doing really hard to understand
11. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
c.pfaffenbichler Mar 17, 2017 7:48 AM (in response to matibuc4eva)How large Is the image in pixels?
12. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
matibuc4eva Mar 17, 2017 8:02 AM (in response to c.pfaffenbichler) -
13. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
c.pfaffenbichler Mar 17, 2017 9:01 AM (in response to matibuc4eva)7093px high – do you really need that big a Pattern?
I suspect you may be wasting your resources here.
14. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
c.pfaffenbichler Mar 17, 2017 9:08 AM (in response to matibuc4eva) -
15. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
matibuc4eva Mar 17, 2017 10:06 AM (in response to matibuc4eva)In fact the problem is not the size. I need to use that size cause is for fabric printing.
The real problem is not even to create an obliqe line pattern.
The real problem is create a SEAMLESS pattern starting from a brush line.
is this possible?
I know that i'm not too mutch skilled so please be patient
16. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
matibuc4eva Mar 17, 2017 10:17 AM (in response to matibuc4eva)The problem is that inside the brush is an effect
17. Re: SEAMLESS OBLIQUE LINES FROM BRUSH
c.pfaffenbichler Mar 19, 2017 11:23 AM (in response to matibuc4eva)1 person found this helpfulTo check and fix seams use the Offset Filter and touch them up before defining the new Pattern.
