3 Replies Latest reply on Mar 20, 2017 4:16 AM by sethup51656429
    Android build error
    sethup51656429 Level 1
      whnen i try to run "phonegap platform add android"
      it gives me Command failed with exit code 1
      can you please help me to solve this
      Moderator note:
      Additional logging information from dup build error with exit code 1 :
      D:\xamp\htdocs\phonegap\backbutton>phonegap platform add android
      Adding android project...
      Creating Cordova project for the Android platform:
              Path: platforms\android
              Package: com.phonegap.helloworld
              Activity: MainActivity
              Android target: android-24
      Subproject Path: CordovaLib
      Android project created with cordova-android@6.0.0
      Installing "com.red_folder.phonegap.plugin.backgroundservice" for android
      ANDROID_HOME=C:\Users\sethu\AppData\Local\Android\sdk
      JAVA_HOME=C:\Program Files (x86)\Java\jdk1.8.0_11
      Starting a new Gradle Daemon for this build (subsequent builds will be faster).
      FAILURE: Build failed with an exception.
      * What went wrong:
      Unable to start the daemon process.
      This problem might be caused by incorrect configuration of the daemon.
      For example, an unrecognized jvm option is used.
      Please refer to the user guide chapter on the daemon at https://docs.gradle.org/
      2.14.1/userguide/gradle_daemon.html
      Please read the following process output to find out more:
      Error occurred during initialization of VM
      Could not reserve enough space for 2097152KB object heap
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug
      option to get more log output.
      Failed to install 'com.red_folder.phonegap.plugin.backgroundservice':Error: cmd:
          at ChildProcess.whenDone (D:\xamp\htdocs\phonegap\backbutton\platforms\andro
      id\cordova\node_modules\cordova-common\src\superspawn.js:169:23)
          at emitTwo (events.js:106:13)
          at ChildProcess.emit (events.js:191:7)
          at maybeClose (internal/child_process.js:877:16)
          at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      Error: cmd: Command failed with exit code 1
      Message was edited by: Kerri Shotts to add logging information from dup https://forums.adobe.com/thread/2291288
        • 1. Re: Android build error
          kerrishotts Adobe Employee
          Try removing all your plugins -- does the issue still occur then?
          • 2. Re: Android build error
            No ...
            It gives
            D:\xamp\htdocs\phonegap>phonegap create android
            You have been opted out of telemetry. To change this, run: cordova telemetry
            Creating a new cordova project.
            Using cordova-fetch for phonegap-template-hello-world
            D:\xamp\htdocs\phonegap>cd android
            D:\xamp\htdocs\phonegap\android>phonegap platform add android
            ls: no such file or directory: D:\xamp\htdocs\phonegap\android\res\mipmap-*
            But when i added a plugin
            D:\xamp\htdocs\phonegap\android>phonegap plugin add https://github.com/Red-Folde
            r/bgs-sample.git
            Fetching plugin "https://github.com/Red-Folder/bgs-sample.git" via git clone
            Repository "https://github.com/Red-Folder/bgs-sample.git" checked out to git ref
            "master".
            Installing "com.red_folder.phonegap.plugin.backgroundservice.sample" for android
            Fetching plugin "https://github.com/Red-Folder/bgs-core.git" via git clone
            Repository "https://github.com/Red-Folder/bgs-core.git" checked out to git ref "
            master".
            * What went wrong:
            * Try:
                at ChildProcess.whenDone (D:\xamp\htdocs\phonegap\android\platforms\android\
            Failed to install 'com.red_folder.phonegap.plugin.backgroundservice.sample':Erro
            com.red_folder.phonegap.plugin.backgroundservice 2.0.0 "Background Service Plugi
            n - Core logic"
            com.red_folder.phonegap.plugin.backgroundservice.sample 2.0.0 "Background Servic
            e Plugin - Sample Background Service"
            • 3. Re: Android build error
              Go to Start->Control Panel->System->Advanced(tab)->Environment Variables->System Variables->New: Variable name: _JAVA_OPTIONS Variable value: -Xmx512M
              This solved my problem and i got successful build...
              thanks guys..for your time
