3 Replies Latest reply on Mar 17, 2017 2:15 AM by Laubender
    The Size of Arrow in the Stroke Panel
    Winfield.Xiao Level 1
      The arrow in the stroke panel can not be lessened while the thickness of path is below 2 points.
        • 1. Re: The Size of Arrow in the Stroke Panel
          Steve Werner Adobe Community Professional & MVP
          Replies will be left here when people can help. Please tell more about your problem. What version of InDesign? What operating system?
          • 2. Re: The Size of Arrow in the Stroke Panel
            Zaid Al Hilali Adobe Community Professional
            Apparently this is a limitation. But you may control your arrow more efficiently in Illustrator, copy it from there then paste it in InDesign if necessary however it will be compound or grouped object.
            • 3. Re: The Size of Arrow in the Stroke Panel
              Hi winfield_xiao,
              if you refer to arrow head scaling using InDesign CC 2017 the range goes from 1% to 1000%.
              Unfortunately the percentages do not follow a linear proportionality of the size we see with 100%.
              My view: That's a big conceptual failure of the feature.
              What you can do to get the size of the arrow head below that limit:
              1. Multiply your stroke weight by 10 to 10 pt
              2. Lower the percentage of the arrow head scaling until it fits your needs in proportion of the stroke
              Beware of a different limit here: Scaling below 65 % could mess with the shape of your arrow head, because the stroke will overlap the arrow head. Another conceptual failure.
              3. Go to Preferences > General and set the scaling preferences to Adjust Scaling Percentage
              4. Scale the object to 10%
              Here two screenshots from my German InDesign.
              Note that I scaled the view to a maximum of 4,000 %
              Depending of the kind of stroke and the kind of arrow head sooner or later you'll see, that the stroke will overlap the arrow head:
