1 Reply Latest reply on Mar 17, 2017 10:40 AM by kerrishotts
    build error with exit code 1
    sethup51656429 Level 1
      D:\xamp\htdocs\phonegap\backbutton>phonegap platform add android
      Adding android project...
      Creating Cordova project for the Android platform:
              Path: platforms\android
              Package: com.phonegap.helloworld
              Activity: MainActivity
              Android target: android-24
      Subproject Path: CordovaLib
      Android project created with cordova-android@6.0.0
      Installing "com.red_folder.phonegap.plugin.backgroundservice" for android
      JAVA_HOME=C:\Program Files (x86)\Java\jdk1.8.0_11
      Starting a new Gradle Daemon for this build (subsequent builds will be faster).
      FAILURE: Build failed with an exception.
      * What went wrong:
      Unable to start the daemon process.
      This problem might be caused by incorrect configuration of the daemon.
      For example, an unrecognized jvm option is used.
      Please refer to the user guide chapter on the daemon at https://docs.gradle.org/
      Please read the following process output to find out more:
      Error occurred during initialization of VM
      Could not reserve enough space for 2097152KB object heap
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug
      option to get more log output.
      Failed to install 'com.red_folder.phonegap.plugin.backgroundservice':Error: cmd:
      Command failed with exit code 1
          at ChildProcess.whenDone (D:\xamp\htdocs\phonegap\backbutton\platforms\andro
          at emitTwo (events.js:106:13)
          at ChildProcess.emit (events.js:191:7)
          at maybeClose (internal/child_process.js:877:16)
          at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      Error: cmd: Command failed with exit code 1
      Can you please help me?
