6 Replies Latest reply on Mar 17, 2017 10:39 AM by Timp1
    Lasso tool issues...
    Timp1
      Afternoon all.
      My Lasso tool appears to be behaving a little erratically.
      When ever a selection is made, it appears to 'snap back' to a kind of oval shape rather than the selection that I have created..
      In addition, the attached error message keeps appearing.
      Can anyone assist please ?
        • 1. Re: Lasso tool issues...
          c.pfaffenbichler Level 9
          What are the Tool’s settings in the Options Bar? (Please post a screenshot including the relevant elements.)
          Have you reset the Tool yet?
          • 2. Re: Lasso tool issues...
            Timp1 Level 1
            Hi...does this illustrate enough ?
            And yes, I have tried resetting the tool
            • 3. Re: Lasso tool issues...
              Simmer1 Adobe Community Professional
              I noticed your feather is set to 35 px this is what would make it go to an oval shape.
              Try setting the feather to 0.
              Sim
              • 4. Re: Lasso tool issues...
                Timp1 Level 1
                Aha !
                Many thanks...I was feathering to retouch skin in frequency separation
                Now...whilst I have your attention ( ) ..I have another issue with the lasso tool.
                I use lasso -edit -fill to remove objects.
                This may also transpire to be user error, however the function no longer seems to be working on a created adjustment layer.
                It seems to be intermittent, and I'm wondering whether I am missing a box to check. When it doesn't  function, it appears as 'clear' in the history, but does not fill or remove the selected area...In addition the shortcut for 'edit - fill' (delete button) does not work on an adjustment layer .Can anyone assist please ?
                • 5. Re: Lasso tool issues...
                  From the second screenshot you sent I can see you have the locked background layer selected.
                  Select the top Layer and it should work.
                  Sim
                  • 6. Re: Lasso tool issues...
                    Timp1 Level 1
                    Hi Sim...thank you for responding.
                    Ironically, I went back and it would allow the 'delete' shortcut to work, and the removal of objects to take place on a locked background layer. As soon as I create another layer with a view to doing any removals on it, it will not allow the shortcut to work, or indeed any removals to take place ...
