• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Key press capturing not working
Community Beginner ,
Mar 17, 2017 Mar 17, 2017
Hi. I'm trying to capture some key presses but nothing seems to happen. Here's my code:
#target illustrator
var palette = new Window("palette", "Animation Settings");
var playButton = palette.add("button", undefined, "Play");
    playButton.addEventListener("keydown", function (kd) {
           testKeyPress(kd);
function testKeyPress(k)
     $.writeln(k.keyName);
palette.show();
Any ideas as to why that doesn't work? I thought you could attach a keypress listener to any UI object? Attaching it to the palette doesn't work either. I'm targeting illustrator CS6
TOPICS
Scripting
Views
409
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Mar 18, 2017 Mar 18, 2017
unfortunately, there's no access to keystroke events using scripting. Except for what you tried above.
Votes
Translate
Translate
Adobe
Community Expert ,
your code works perfectly. Just make sure to button is "Active" or it has the "Focus". Do that by pressing TAB key once.
Votes
Translate
Translate
Report
Report
Hi CarlosCanto​. I see that makes sense. What I'd like to do though is be able to listen for key presses globally without having to focus on any object. Do you know how I would do that?
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Valorous Hero ,
LATEST
The same code attached to the window object works, as long as someone 'tabs' into the window, making the button have its blue fill.
function test(){
    #target illustrator
    palette.addEventListener("keydown", function (kd) {
           testKeyPress(kd);
  palette.onShow = function(){
    playButton.active = true;
     $.writeln(k.keyName + " : " + k.target);
palette.show();
test();
Votes
Translate
Translate
Report
Report
