4 Replies Latest reply on Mar 20, 2017 7:58 AM by PetRokTech
    New __SaveOptions() instance in function crashes Photoshop
    PetRokTech Level 1
      Greetings! I previously wrote this script for incrementing file names in Photoshop quickly. It's sloppy code, but it works as expected.
      Today I decided to clean the code up and move some lengthy code that gets used twice into a separate function. The new code is below.
      The new JPEGSaveOptions(), new PNGSaveOptions(), new PhotoshopSaveOptions(), and new TiffSaveOptions() commands were moved from the main body of the code to the function saveFile at the bottom of the code. When Photoshop executes these lines (in red below) to instantiate new SaveOptions objects, it crashes without error message. There is no error noted in ExtendScript ToolKit, which continues running just fine.
      Any ideas why this would happen? I'm guessing it's related to the scope of the document, but I'm not sure what the remedy would be aside from reverting back to the unabstracted code.
      Thank you all for your time and help! :]
      // Script by Vince Petaccio of PetRok Studios. | www.PetRokStudios.com
      // Ensure a document is open
      if ( documents.length > 0 )
          // Change dialog settings
        var originalDialogMode = app.displayDialogs;
        app.displayDialogs = DialogModes.ERROR;
          try
          // Get the document
              var docRef = activeDocument;
              // Get the path for the document
              var filePath = docRef.path + '/';
              // Get the filename of the document
              var fileNameNoExtension = docRef.name;
              // Split the filename at the dots
              fileNameNoExtension = fileNameNoExtension.split( "." );
              // If there's a dot, remove everything after the last dot
              if ( fileNameNoExtension.length > 1 ) {
                  // Get the file type
                  fileType = fileNameNoExtension[fileNameNoExtension.length-1];
                  // Decrement the filename object by removing the last element (the stuff after the last .)
                fileNameNoExtension.length--;
                  // Reconnect everything BEFORE the first .
                  fileNameNoExtension = fileNameNoExtension.join(".");
              // Get the last five characters of the filename
              lastFive = fileNameNoExtension.slice(-5);
              allButFive = fileNameNoExtension.slice(0,-6);
              // Check whether the last five characters are digits
              newDoc = isNaN(parseInt(lastFive))
              // If this is a new document, then add _00000 to the file name
              if (newDoc) {
                  // Make the new file name
                  newFileName = fileNameNoExtension + '_00000';
                  // Do the saving
                  saveFile(fileType.toLowerCase(), docRef, newFileName)
              // Otherwise, find the lowest number of the file name that does not exist, starting at the index of the file name's digits
              else {
                  // Create the needName switch
                  needName = 1
                  // Get the file number
                  fileNumber = Number(lastFive);
                  while (needName) {
                      // Increment the file number
                      fileNumber = fileNumber + 1;
                      // Make the file number 4 digits with zeros
                      switch ((fileNumber.toString()).length) {
                          case 1:
                              newFileName = allButFive + '_0000' + fileNumber.toString();
                              break;
                          case 2:
                              newFileName = allButFive + '_000' + fileNumber.toString();
                              break;
                          case 3:
                              newFileName = allButFive + '_00' + fileNumber.toString();
                              break;
                          case 4:
                              newFileName = allButFive + '_0' + fileNumber.toString();
                              break;
                          case 5:
                              newFileName = allButFive + "_" + fileNumber.toString();
                              break;
                      // Do the saving
                      needName = saveFile(fileType.toLowerCase(), docRef, newFileName)
          catch(e)
              // An error occured; restore dialog mode and display the error
              app.displayDialogs = originalDialogMode;
              throw e;
      else
          alert( "There's no file open! GET TO WORK!!!!");
      // Function for saving the file
      function saveFile(fileType, docRef, newFileName) {
          needName = 1;
          switch (fileType.toLowerCase()) {
              case 'psd': // Photoshop file
                  thisSameFile = docRef.path + '/' + newFileName + '.psd';
                  saveFile = new File(thisSameFile);
                  if (saveFile.exists) {
                      break;
                  else {
                      saveOptions = new PhotoshopSaveOptions();
                      saveOpt.embedColorProfile = true;
                      saveOpt.layers = true;
                      app.activeDocument.saveAs(saveFile,saveOpt,true,Extension.LOWERCASE);
                      needName = 0;
                      app.activeDocument.close(saveOpt.DONOTSAVECHANGES);
                      open(saveFile);
                      break;
              case 'jpg': // JPEG file
                  thisSameFile = docRef.path + '/' + newFileName + '.jpg';
                      break;
                  else {
                      saveOpt = new JPEGSaveOptions();
                      saveOpt.formatOptions = FormatOptions.STANDARDBASELINE;
                      saveOpt.matte = MatteType.NONE;
                      saveOpt.quality = 12;
                      needName = 0;
                      open(saveFile);
                      break;
              case 'png': // PNG file
                  thisSameFile = docRef.path + '/' + newFileName + '.png';
                      break;
                  else {
                      saveOpt = new PNGSaveOptions();
                      saveOpt.compression = 0;
                      needName = 0;
                      open(saveFile);
                      break;
              case 'tif': // TIFF file
                  thisSameFile = docRef.path + '/' + newFileName + '.tif';
                      break;
                  else {
                      saveOpt = new TiffSaveOptions();
                      saveOpt.layers = false;
                      saveOpt.transparency = true;
                      needName = 0;
                      open(saveFile);
                      break;
          return needName;
        • 1. Re: New __SaveOptions() instance in function crashes Photoshop
          What crashes? Photoshop?  Have you tried running the script in Photoshop not using ExtendScript ToolKit run it from Photoshop menu File>Scripts>Script File. Was a crash report generated? Running your script that way on my system the Photoshop crash is in extendscript.dll.... Even when the save option code is commented out it crashes so it not the statement in red causing the crash...
              try
              // Get the document
                  if (newDoc) {
                      // Do the saving
                  else {
                      needName = 1
                      while (needName) {
                              case 1:
                                  break;
                              case 2:
                                  break;
                              case 3:
                                  break;
                              case 4:
                                  break;
                              case 5:
                                  break;
                          // Do the saving
              catch(e)
                  throw e;
          else
              needName = 1;
                          break;
                      else {
                          needName = 0;
                          open(saveFile);
                          break;
                          break;
                      else {
                          needName = 0;
                          open(saveFile);
                          break;
                          break;
                      else {
                          needName = 0;
                          open(saveFile);
                          break;
                          break;
                      else {
                          needName = 0;
                          open(saveFile);
                          break;
              return needName;
          • 2. Re: New __SaveOptions() instance in function crashes Photoshop
            PetRokTech Level 1
            Hi JJMack, thanks so much for taking the time to help me out!
            The crash does indeed occur when I run the script this way, in both CC 2015 and in CC 2017.
            The mode of failure is a "Photoshop has stopped working..." error, depicted below.
            Curious that you've encountered the error with that line commented out- when I run the code in debug mode, it runs perfectly until it crashes as those lines. This is what lead me to the conclusion that the problem was related to them. Though I wouldn't expect the code to run with those lines commented out, since they define variables used later in the code.
            • 3. Re: New __SaveOptions() instance in function crashes Photoshop
              The problem seems to be is that you seems to be using "saveFile" as both a Function Name and a Variable. I changed the function name to saveFileF
                  try
                  // Get the document
                      if (newDoc) {
                          // Do the saving
                          saveFileF(fileType.toLowerCase(), docRef, newFileName)
                      else {
                          needName = 1
                          while (needName) {
                                  case 1:
                                      break;
                                  case 2:
                                      break;
                                  case 3:
                                      break;
                                  case 4:
                                      break;
                                  case 5:
                                      break;
                              // Do the saving
                              needName = saveFileF(fileType.toLowerCase(), docRef, newFileName)
                  catch(e)
                      throw e;
              else
              function saveFileF(fileType, docRef, newFileName) {
                  needName = 1;
                              break;
                          else {
                              needName = 0;
                              open(saveFile);
                              break;
                              break;
                          else {
                              needName = 0;
                              open(saveFile);
                              break;
                              break;
                          else {
                              needName = 0;
                              open(saveFile);
                              break;
                              break;
                          else {
                              needName = 0;
                              open(saveFile);
                              break;
                  return needName;
              • 4. Re: New __SaveOptions() instance in function crashes Photoshop
                PetRokTech Level 1
                WOW do I feel silly. Amateur hour in here, eh?
                Thanks so much for your help! Everything is working as expected now with that change.
