3 Replies Latest reply on Mar 19, 2017 3:07 PM by Trevor.Dennis
    Unable to use or apply brush to any layer.
    Indie767 Level 1
      I upgraded to the latest version of PS 2017. Suddenly, I cannot apply brush strokes to any layer. I created a rectangle layer and PS asked me to rasterize it. I did but I still cannot apply my brush to that or any other layer. Should I go back to the previous working version of PS or what?
        • 1. Re: Unable to use or apply brush to any layer.
          If the rectangle layer you create is a shape layer you can not paint on it unlest you convert it to a normal pixels layer by rasterizing it.
          • 2. Re: Unable to use or apply brush to any layer.
            Indie767 Level 1
            JJ,
            Thanks, I am aware that I have to rasterize a shape layer before I apply a brush or pen to it. I was trying to use a project created in an earlier version (PS 2105.5) and realized that I cannot modify projects created in previous versions of PS.  I'm back using PS 2015.5 so all is good.
            • 3. Re: Unable to use or apply brush to any layer.
              Trevor.Dennis Adobe Community Professional (Moderator)
              There are a number of things that could cause this.
              The bush blend mode in the options bar would be my first guess.
              Brush opacity and flow my second guess.
              Is the foreground colour the same as the image background?
              Are the layers locked?
              Are you using a tablet, and if yes, do you have the pen the right way round? (sorry but have to ask)
              What is the image size? If it is huge (30,000 pixels) then a 1 pixel brush would not show if zoom is at fit to screen.
              If you create a new blank document, does the brush work in that?  Image documents can go weird sometimes.  If you have done a lot of work already, then grouping all the layers and duplicating to a new document can fix this.
