When I open AfterFX it loads until it reaches "MediaCore" and then I get "dynamiclinkmanager has stopped working" I've tried re-installing it and it still tells me the same thing
Nobody can tell you anything without exact system info or other technical details such as the detailed crash info. Most of the time this happens when the local ports used by DyanmicLink are blocked by some external tool or setting.
Mylenium
Hi MateoBolmir,
Did you ever solve this issue? If not, please see this document: After Effects or Premiere Pro crashes after starting
Please let us know if it helps you.
Kevin
