Hello
Anyone using Publish online option of Indesign. I am facing some problem while converting to swf file.
Help required.
[Moved from the Lounge (which is where you can "connect with your peers" from across all of Adobe's products for conversations that don't directly relate to help and support) to a product-specific support forum - moderator]
There is no connection whatsoever between Publish Online (which is using HTML5 and CSS) and SWF (which is using Flash).
Sorry for placing an unclear question.
Actually when I create an Indesign document with animation, interactivity, sound etc and publish it online its work fine in browser but the same file when I convert it into swf and if there is sound too animation stops. But if i remove sound and convert it into swf all the links and animation work.
Yes I understand the difference but the problem is as follows:
When I create an Indesign document with animation, interactivity, sound etc and publish it online its work fine in browser but the same file when I convert it into swf and if there is sound too animation stops. But if i remove sound and convert it into swf all the links and animation work.
The question is not really clear:
if the source is an InDesign file then you simply publish this as Publish online.
You can not 'convert' a SWF file back to use on Publish Online, also a placed SWF file in an InDesign document will not play.
