5 Replies Latest reply on Apr 24, 2017 8:44 AM by petertogel
    Catalog import painfully slow
      I consolidated several catalogs into the master. On average 400GB each one with any issue at all.
      The last one - smaller than those imported previously, has achieved 1/6 of the import in 24 hrs projecting to be completed in the next 3+ days!!!
      Before importing it I:
      • checked free space on both the source and the destination drives: 2+TB free on each one;
      • optimized the catalog
      Clearly the UI is not providing any feedback (Adobe, improving this process?) and frankly not sure what I could have done or do differently considering that al my previous imports lasted on average 20 min and worked fine.
      Should I abort the import? Did it once after 4 hrs, but the second attempt hasn't delivered a better outcome.
      Just wait till the end of the week?
      Thanks, Stefano
        • 1. Re: Catalog import painfully slow
          ManiacJoe Adobe Community Professional
          Are the LrCat files really 400 GB in size, or is that including the preview folders?
          If the LrCat files are really that big, I would leave them as separate catalogs for performance reasons unless you really have a need to merge them.
          • 2. Re: Catalog import painfully slow
            dj_paige Level 9
            Slow importing can be a hardware problem, perhaps a bad card reader/bad USB cable/bad connection to the camera or to the USB port. I would certainly investigate this, and try importing with different hardware.
            • 3. Re: Catalog import painfully slow
              bob frost Level 3
              Try aborting the import, closing LR, and rebooting the computer. See if that speeds things up.
              Bob Frost
              • 4. Re: Catalog import painfully slow
                smaruzziUK Level 1
                I eventually managed to consolidate all my catalogues in a master, now 3.4GB in total size and roughly 190K images.
                Performance seem OK.
                I decided to break down the catalog that required several days to complete the import process in four smaller portions of almost identical dimensions. This solution dramatically shortened the entire process. What will remain a mystery is why two of the four new catalog required several hours each, while the other two completed the process in a matter of minutes.
                Had a conversation with Richard Curtis from Adobe at the Birmingham Photography Show and he strongly recommended to create a single catalog with Smart Previews (he claims to have a Master catalog with 300+K images).
                Waiting for Apple to introduce new high performance iMacs with Type C ports, to further improve performance.
                Thanks, Stefano
                • 5. Re: Catalog import painfully slow
                  Our catalog is 943315 images but it is getting dang slow on imports from other catalogs because it tries to compare each image agains the ones that are in db.
