8 Replies Latest reply on Mar 21, 2017 4:39 PM by pixxxel schubser
    Script stops after one cycle
    johny roger Level 1
      Hello All
      I created a (my first) script which should loop the construct() function until my layer named "END" has been reached. But it always runs just one cycle.
      My main part looks like this:
      var end_reached = false;
      // Check if last layer named "END" in "Front.psd" have been reached and stop script / otherwise repeat function "construct".
        for(var i = 0; i < designDoc.layers.length; i++){
            var layer = designDoc.layers[i]
          if(currentLayer.name.toLowerCase().indexOf("end") >= 0){
                  alert ('All Designs have been Applied', 0);
                  end_reached = true
                  break;
        if (!end_reached) {
            construct()
      The complete script looks like that:
      //================================= OPTIONS =================================
      // jpg options.
        var jpegOptions = new JPEGSaveOptions();
        jpegOptions.quality = 9;
        jpegOptions.embedColorProfile = true;
        jpegOptions.matte = MatteType.NONE;
      // PNG options.
          pngOptions = new PNGSaveOptions()
          pngOptions.compression = 0
          pngOptions.interlaced = false
      //================================= VARIABLES =================================
      // Variables for the "Paste in Place" function
        cTID = function(s) { return app.charIDToTypeID(s); };
        sTID = function(s) { return app.stringIDToTypeID(s); };
      // Checks which one is the Mockup.psd file (as my names differ but allways contain "Mockup")
        var docs = app.documents;
        for(var i = docs.length - 1; i >= 0; i--){
        if(docs[i].name.indexOf('Mockup') > 0){
            var mockupDoc = docs[i];
      // Setting variable for layerset "GTO Background" and set it to visible
        var gtoBG = mockupDoc.layerSets.getByName("GTO Background");
      // This stores Front.psd file's name so Photoshop can look for the active layers in the correct document.
        var designDoc = app.documents.getByName("Front.psd");
        var currentLayer = designDoc.activeLayer;
      // Getting the name and location of Mockup.psd;
        var mockupDocName = mockupDoc.name;
        if (mockupDocName.indexOf(".") != -1) {var basename = mockupDocName.match(/(.*)\.[^\.]+$/)[1]}
        else {var basename = mockupDocName};
      // Getting the location of Mockup.psd;
        var mockupDocPath = mockupDoc.path
      //================================= MAIN =================================
      // Check if last layer named "END" in "Front.psd" have been reached and stop script / otherwise repeat function "CreateItems".
                  end_reached = true
                  break;
        if (!end_reached) {
            construct()
      //================================= FUNCTION TO EXPORT PNG and JPG FROM EACH DESIGN (var designDoc aka FRONT.psd) =================================
      function construct() {
      // Sets "FRONT.psd" aka designDoc as active document.
        app.activeDocument = mockupDoc;
      // Toggles layerset "GTO BBACKGROUND" to visible for .jpg version export.
        gtoBG.visible = true;
        app.activeDocument = designDoc;
      // This selects and makes next Layer in Front.psd visible (only this one)
        for(i=0; i < designDoc.layers.length; )
        if(designDoc.layers[i]==currentLayer)
            a=i;
            //alert(a);
            i = designDoc.layers.length;
        else{ i++; }
        try
        var nextLayer = designDoc.layers[a+1];
        var check = nextLayer.visible;
        catch(e)
        var nextLayer = designDoc.layers[0];
        designDoc.activeLayer = nextLayer;
        if (check == false)
        designDoc.activeLayer.visible = false;
       // Makes only selected layer in "Front.psd" aka designDoc visible.
        toggleVisibility();
      // Saves "Front.psd" to original destination and updates embeded content (smart object) in "Mockup.psd" aka mockupDoc
        var designDocPath = designDoc.path
        var Name = designDoc.name.replace(/\.[^\.]+$/, '');
        designDoc.saveAs(File(designDocPath + "/" + Name + ".psd"));
      // Make "Mockup.psd" aka mockupDoc file active document
      // Checks if current Design is a "FLEX" print or not.
        if(designDoc.activeLayer.name.toLowerCase().indexOf("flex") >= 0){
        // Hides Texture Overlays
         Selecttexures();
      // Creates a Sharpness Layer for the jpg version.
        createSharpnessLayer ()
      // Saves the composited image from Mockup.psd containing Filename minus "Mockup", Name of the visible layer "Colors" layerset and the Name of the active layer in Front.psd
        mockupDoc.saveAs((new File(mockupDocPath+'/' + basename + ' ' + designDoc.activeLayer.name +'.jpg')),jpegOptions,true);
      // Remove OLD Sharpness Layer
        mockupDoc.layers.getByName('Sharpness').remove();
      // Toggles layerset "GTO BBACKGROUND" to hidden for .png version export.
        gtoBG.visible = false;
      // Creates a Sharpness Layer for the png version.
        mockupDoc.saveAs((new File(mockupDocPath+'/' + basename + ' ' + designDoc.activeLayer.name +'.png')),pngOptions,true);
      } //END Create Items function
      //================================= HELPERS =================================
      // "Paste in Place" function.
      function pasteInPlace(enabled, withDialog) {
          if (enabled != undefined && !enabled)
          return;
          var dialogMode = (withDialog ? DialogModes.ALL : DialogModes.NO);
          var desc1 = new ActionDescriptor();
          desc1.putBoolean(sTID("inPlace"), true);
          desc1.putEnumerated(cTID('AntA'), cTID('Annt'), cTID('Anno'));
          executeAction(cTID('past'), desc1, dialogMode);
      // "Toggle Visibility" function is the same as Alt/Click on a layers eye.
      function toggleVisibility() {
        var desc = new ActionDescriptor();
        var list1 = new ActionList();
        var ref = new ActionReference();
        ref.putEnumerated( charIDToTypeID('Lyr '),charIDToTypeID('Ordn'),charIDToTypeID('Trgt') );
        list1.putReference( ref );
        desc.putList( charIDToTypeID('null'), list1 );
        desc.putBoolean( charIDToTypeID('TglO'), true );
        executeAction( charIDToTypeID('Shw '), desc, DialogModes.NO );
      // Create "Sharpness" Layer.
      function createSharpnessLayer () {
        mockupDoc.selection.selectAll();
        mockupDoc.selection.copy(true);
        pasteInPlace();
        mockupDoc.activeLayer.name = "Sharpness"
        mockupDoc.activeLayer.move( mockupDoc, ElementPlacement.PLACEATBEGINNING );
        mockupDoc.activeLayer.applyHighPass(0.5)
        mockupDoc.activeLayer.blendMode  = BlendMode.LINEARLIGHT;
        mockupDoc.activeLayer.opacity = 50;
      // Select all print texture overlays in "Mockuo.psd" aka mockupDoc
      function Selecttexures() {
        // Select
        function step1(enabled, withDialog) {
            return;
          var ref1 = new ActionReference();
          ref1.putName(cTID('Lyr '), "LIGHT FABRIC TEXTURE");
          desc1.putReference(cTID('null'), ref1);
          desc1.putBoolean(cTID('MkVs'), false);
          list1.putInteger(43);
          desc1.putList(cTID('LyrI'), list1);
          executeAction(cTID('slct'), desc1, dialogMode);
        // Select Linked Layers
        function step2(enabled, withDialog) {
            return;
          ref1.putEnumerated(cTID('Lyr '), cTID('Ordn'), cTID('Trgt'));
          executeAction(sTID('selectLinkedLayers'), desc1, dialogMode);
        // Hide
        function step3(enabled, withDialog) {
            return;
          list1.putReference(ref1);
          desc1.putList(cTID('null'), list1);
          executeAction(cTID('Hd  '), desc1, dialogMode);
        step1();      // Select
        step2();      // Select Linked Layers
        step3();      // Hide
      Any help highly appreciated as i'm a beginner and as it seems, i can't find the reason for the issue myself.
        • 1. Re: Script stops after one cycle
          Jarda Bereza Level 4
          Try ExtendSript Toolkit, paste your code here, set breakpoint on the first line and run script. Then click on next button again and again to see what is going on in each line of code. Don't forget look inside variables. E.g. length of your layers.
          • 2. Re: Script stops after one cycle
            To process all layers in a document I normally see recursion being used to process layers in layer groups. I do not see anything like that in your script. Can your Photoshop contain layer groups?
            • 3. Re: Script stops after one cycle
              johny roger Level 1
              Hello JJMack
              no, the document to be processed contains only layers and no layersets. I will try Jerda's suggestion and check in The ES Toolkit why the action stops. Think the issue could be in these lines:
                    a=i;
                    //alert(a);
                else{ i++; }
                try
                catch(e)
                if (check == false)
              • 4. Re: Script stops after one cycle
                johny roger Level 1
                Hello Jarda
                I opened the script in Extended Script Toolkit and did run it. It throes no errors and plays the main function one time but does not start again from the beginning?
                Probably my understanding of how a function is executed is completely wrong. Does a function not being repeated over and over again if no "break" (or other) argument has been executed/reached?
                What tells the last line of function code to start again from the beginning?
                Sorry if this is a stupid question, but i'm just starting my scripting experience
                • 5. Re: Script stops after one cycle
                  johny roger Level 1
                  Ok, seems i have found the issue. My Loop was not executing as it should.
                  Changed to the following and it works now :
                  var create = true;
                  while (create) {
                      //Do main function
                    if(designDoc.activeLayer.name.indexOf("END") >= 0){
                              var create = false; //While loop stops when my IF argument has become true
                  • 6. Re: Script stops after one cycle
                    This will fall into endless loop without layer "END"
                    Please read some documentation how loops works: JavaScript for Loop
                    If this code fail:
                    Wrap it into Try/catch
                    JavaScript Errors Try Catch Throw
                    • 7. Re: Script stops after one cycle
                      johny roger Level 1
                      Jarda
                      Thanks for the heads up. I will look into it, but basically it should loop for a unlimited amount of cycles until the layer END is present. I tried with looping trough the documents layers length and letting the loop cycle for this amount. Unfortunately i could not get it working.
                      • 8. Re: Script stops after one cycle
                        pixxxel schubser MVP & Adobe Community Professional
                        https://forums.adobe.com/people/johny+roger  schrieb
                        …but basically it should loop for a unlimited amount of cycles until the layer END is present …
                        But please read carefully what Jarda Bereza wrote
                        That why: check at first (before a while loop) if the layer "end" really in your document exists and if the script really can reach the layer in the while loop.
                        Otherwise: This will fall into endless loop without layer "END"
