3 Replies Latest reply on Mar 20, 2017 10:30 PM by stephc51503605
    ADE is not working
    sspears35 Level 1
      I'm not sure exactly what is going on but my Adobe Digital Editions is not working. Approximately one month ago, my ADE (version 3), which I had for several years, would not let me download books or return books from my library. I read some information about deauthorizing and authorizing ADE which I did. In the process of doing this I learned there was a newer version (4.5) which I downloaded and authorized. It worked. Yesterday, it stopped working. I tried to download a book, I get this message:
      Error getting License. License Server Communication Problem:
      E_AUTH_BAD_DEVICE_KEY_OR_PKCS12
      That is the same message I get when I try to return a library book as well.
      When I try to deauthorize ADE so that I can reauthorize it, I get this message
      Unable to Erase Authorization. Please try after some time.
      I have been getting this message since yesterday.
      If anyone has any idea what might be going on, I would be deeply appreciative if you could point me in the right direction.
      Sharon
        • 1. Re: ADE is not working
          stephc51503605
          I am having the very same problem and it is making me CRAZY. It hasn't worked in ages and I miss my books!
          "Unable to Erase Authorization. Please try after some time." is actually causing my blood pressure to go up.
          I feel better knowing it is not just me but I would feel even better if someone could help us!
          • 2. Re: ADE is not working
            sspears35 Level 1
            I actually found the below answer, applied it and it works (on my Mac). Here's what someone said to do. Good luck. I know how frustrating it can be to fix this:
            If due to some reason, you are unable to deauthorize ADE, follow the below steps:
            Mac:
            1. Go-> Go to folder.
            Go to folder dialog will appear.
            2. Type   ~/Library/Application Support/Adobe/Digital Editions
            drag the activation.dat file to the trash.
            ADE will be deauthorized now.
            Now Authorize ADE again.
            Windows:
            Choose Start > Run.
            In the Open text box, type regedit and then press Enter. The Registry Editor opens.
            In the left pane of the Registry Editor, locate the following registry key:
            HKEY_CURRENT_USER\Software\Adobe\Adept
            Right-click the Adept key and choose Delete.
            In the Confirm Key Delete dialog, click OK.
            Your authorization will be deleted.
            Error will be fixed !!
            • 3. Re: ADE is not working
              stephc51503605 Level 1
              THANK YOU! That worked on my Mac. Awesome.
