Dear Friends,
I want to develop an extension for CC 2015.3 plugin with two dialogs.
when I click a button(Show Dialog) in first dialog will show the second dialog(with button,textbox controls).
I look at Illustrator SDK samples. all the UI samples are shows that a single dialog in an Extension.
I am having doubt, Is It possible to create an extension(zxp) with two dialogs.
If it is possible then give your suggestion to create extension with two dialogs.
Thank you Friends,
Nathan.
Yes it is possible, you just add extra Extension objects to the ExtensionList in your manifest.xml. You need to specify a different Id for each extension, a different html file for the MainPath and a different Menu if you are using menus to show your dialog.
Dear Friend,
Thank you for your suggestion.
When I click a button(Show Sub Dialog) in main dialog then the Sub Dialog is Shown as my expectation.
But there was a problem,The Main Dialog is Accessible at the time of Sub Dialog is shown.
I want to restrict the access of Main Dialog at the time of Sub Dialog is shown.
Is it possible in Mac machine.
please give your suggestion.
Thank you friend,
Nathan.
Did you set the Extension Type to ModalDialog for the Sub Dialog?
Dear Friend,
Thank you for your Immediate reply.
No,I already set it as Panel.
Now I change it to ModalDialog and it works fine now.
Thank you Friend,
Nathan
Dear Friend,
I have Create a FlashUI With 2 Dialogs.
When I click a button(Show Sub Dialog) in main dialog then the Sub Dialog is Shown .
But the Controls Are Not Shown in the Second Dialog(Created as Panel or ModalDialog).
please give your Suggestion to Solve this Problem.
Thank you Friend,
Nathan.
