3 Replies Latest reply on Aug 23, 2008 1:50 PM by kglad
    Setting an expression variable
      Hi, I've created a small piece of Flash for a client which will work as an ad on external sites, with a clickthough link.
      I've been asked to follow some simple instructions to create the link. My Actionscript skills are pretty minimal, though. I need to send it along to another agency, so don't have the luxury of being able to test if it works in situ - I'd appreciate some help.
      The instructions I've been given are:
      "1. Select your button instance in the flash movie
      2. Add mouse event On(release)
      3. add get url command Get URL( )
      4. Set URL to clickTAG (make sure this URL is an expression variable)
      5. Set window target to _blank
      Typical action code
      On (release)
      Get URL (clickTAG, window="_blank")
      End On
      It is essential that the clickTAG variable is set to be an expression"
      Now, I've created a big 'invisible button' over the animation with:
      on(release) {
      Is that correct? Also, please let me know how I set the variable to be an expression, and where that code should go.
      Many thanks in advance, Reg
