8 Replies Latest reply on Mar 22, 2017 2:51 AM by davescm
    Colorizing black
    T Cox Level 1
      I tried unsuccessfully to colorize a black image. The file type was PSD. The color mode was RGB. I used an Saturation/Hue adjustment layer. I chose the colorize option. The black remained unchanged regardless how I manipulated the hue/saturation/lightness sliders. I tested the same approach with a color object. It worked as expected. Am I correct in assuming that black is not considered a hue in this context, and therefore isn’t affected by the tool?
        • 1. Re: Colorizing black
          davescm Adobe Community Professional
          No that would not be correct
          See below
          Start (no adjustment):
          Lightness increased :
          Hue changed with lightness still turned up:
          Lightness up to max :
          Is the blending mode of your Hue/Sat layer set to normal?
          Dave
          • 2. Re: Colorizing black
            T Cox Level 1
            Aha. I see my error. I left ‘lightness’ on zero. Increasing the lightness revealed the applied color.
            • 3. Re: Colorizing black
              No problem. Glad we got it sorted
              Dave
              • 4. Re: Colorizing black
                D Fosse Adobe Community Professional & MVP
                Yeah, but it only works with increased lightness - IOW moving the values up from 0/0/0 thus turning black into "something else".
                0/0/0 has no color by definition, and therefore no saturation. There's nothing to adjust, and nothing to colorize. No tonal adjustments work on pure black or pure white.
                • 5. Re: Colorizing black
                  T Cox Level 1
                  Makes sense now. Logically, black is already as dark as it can be. Decreasing the lightness has no effect. However, once I increased the lightness, I was able to apply a different hue, adjust its saturation, and adjust the lightness in either direction.
                  • 6. Re: Colorizing black
                    Of course - hence the need to move the lightness slider to change away from black .
                    Dave
                    • 7. Re: Colorizing black
                      I know you know this, Dave.
                      I just wanted to be very specific about it because many people miss the significance of black and white in an RGB model. We see questions about this quite often (why can't I turn this black into green, using x adjustment).
                      In fact it's also related to the classic 100% view thing: People come in with a black and white line drawing, and try to "lighten it up" using a mid-levels adjustment, or some other color adjustment tool. And that seems to work, because the screen resampling turns some of that black and white into gray - until they flatten and are left with the very same black and white.
                      • 8. Re: Colorizing black
                        Good points Dag - and no problem at all
                        Dave
