1 Reply Latest reply on Mar 22, 2017 2:36 AM by c.pfaffenbichler
    Export multiple layer combinations to pdf
    clayd85047281 Level 1
      I need to print (or export, depending on how you look at it) multiple layer combinations to .pdf from Photoshop CC 2015
      Example: Traveling Salesman. Contact info should be specific to branch location and sales person, but they could change often.
      Layer Group1: Branch
      Atlanta
      Dallas
      Phoenix
      Portland
      Layer Group 2: Salesperson
      John
      David
      Beth
      Lisa
      Layer Group 3 is all of the components that make up the rest of the document. I want this group untouched.
      Need a VBScript that will return all permutations of those two top level groups:
      Atlanta, John
      Atlanta, David
      Atlanta Beth
      Atlanta, Lisa
      Dallas John
      Dallas David
      Dallas Beth
      Dallas Lisa
      on an on and on ...
      Of course, if it were only 16 permutations, I would print them manually. But my real world example is 150. And the input info changes. So I need to be able to add/remove a few layers at a time and then generate a new batch of pdf outputs.
      Can anyone help, PLEASE??
        • 1. Re: Export multiple layer combinations to pdf
          c.pfaffenbichler Level 9
          Have you given this a look-see yet?
          Creating data-driven graphics in Photoshop
          If it should not meet your needs (which does not seem unlikely) I would recommend you abandon VB for this task, use JavaScript instead and ask for help/advice over at
          Photoshop Scripting
          And I am not making a judgement on the validity of VB here it’s just that most of the regulars on that Forum seem to prefer using the platform-independent JS.
          And please provide more details, maybe even a (small) sample file to better illustrate the layer structure and the intended results.
          Do you ultimately need x individual pdfs or one pdf containing all the permutations?
