13 Replies Latest reply on Mar 22, 2017 1:37 PM by richardb75941634
    pdf output scale
    richardb75941634
      I have a 42 page document intended to be used to make 8.5" x 5.5" booklets, which has worked fine on my home printers. I need to send this file, page by page, to a printing firm who have asked for the pages in a pdf file. When I output the pdf, with printer marks, the scale nearly fills the letter size, less some space needed for the printer's marks. The bleeds are trimmed, so the file is worthless, even if the printer could change the scale.
      I am using InDesign 12.0.0.81 on a Mac.
      When I output a ps file, the scale and bleeds are correct, but it outputs only one file at a time, which I can only open in Illustrator.
      The document set-up says that the page is half-letter. It seems impossible to get InDesign to output this correctly. What am I doing wrong? Please?
      Reading the manual has been no help.
      [Moved from the Lounge (which is where you can "connect with your peers" from across all of Adobe's products for conversations that don't directly relate to help and support) to a product-specific support forum - moderator]
        • 1. Re: pdf output scale
          BobLevine MVP & Adobe Community Professional
          How do you know the size is off. Where are you measuring this?
          • 2. Re: pdf output scale
            BarbBinder Adobe Community Professional
            Is this a result of printing test pages to see if there were exported correctly? Acrobat has a Fit setting in the print dialog box that will scale the contents up or down when you print. Choose Actual Size instead.
            Better yet, go to File > Properties > Description to check the paper size. What does it say?
            • 3. Re: pdf output scale
              Derek Cross Adobe Community Professional
              Are you using InDesign's Acrobat PDF Presets and selecting (unless your printer has specified otherwise) PDF/X-4, and then single pages (not spreads) and ticked Use Document Bleed Settings?
              • 4. Re: pdf output scale
                richardb75941634 Level 1
                That is an interesting question. I am loading the pdf with two different readers (including Adobe's Reader) and with Preview. Perhaps they just fill the page? Oddly, Preview shows the bleed properly (3mm beyond the cut marks) while Reader stops bleeding at the cut mark. But as you suggest, perhaps my printer can make this file fit the 8.5 x 5.5 form with some other software? The file cannot be directly scaled as the printer marks give it an unclear ratio. Thanks.
                • 5. Re: pdf output scale
                  My non-profit pays annually for InDesign. Does this mean that we have to pay more to control the output? I can specify the size I want in InDesign and can output a booklet on my office printer, but I was puzzled that I cannot output single page with the crop marks and bleed to scale to review.  It looks as though I have to buy Acrobat, unless my printer can use it.
                  Thanks very much for the answer.
                  • 6. Re: pdf output scale
                    Steve Werner Adobe Community Professional & MVP
                    You don't need Acrobat (the paid version). You can get the same printing from Adobe Acrobat Reader (the free downloadable version).
                    • 7. Re: pdf output scale
                      There's no reason to output postscript files. Use File>Export and use the PDF/X-4 preset. Exporting doesn't allow page scaling, so there's no chance the exported PDF would be anything other than 100% scale.
                      • 8. Re: pdf output scale
                        As per Steve ^^, Reader has the exact same settings in File > Print, and the same ability to see the document size in File > Properties > Description.
                        What is your document size as displayed in the Document Properties dialog box?
                        • 9. Re: pdf output scale
                          I have done this, but it has had little effect on the output, except that now the pdf extends the bleeds properly.
                          Perhaps what I want to do, see the printer images to scale on my office printers, is not something that people really need. The complexities of InDesign have been a challenge, but the capabilities are extraordinary.
                          Thanks.
                          • 10. Re: pdf output scale
                            Thanks very much Steve. This did exactly what I wanted.
                            Everyone in this forum is exceptionally helpful to a printing neophyte struggling to learn terminology way out of my depth.
                            • 11. Re: pdf output scale
                              The document is "half letter" or 8.5 x 5.5. It prints exactly as I want if I first output a pdf, read it into Adobe Reader, then output it in "actual size." That should have been obvious to me...it wasn't.
                              Many thanks.
                              • 12. Re: pdf output scale
                                Great! That print setting (Fit) in both applications trips up a lot of people! Glad it is now behind you.
                                • 13. Re: pdf output scale
                                  Reader seems to have a save option that outputs the page at the scale I will print it. I have the embarrassing feeling that my printer has no problem with the pdf I sent in the first place, but having things printed in China create a language barrier that left me bewildered.
                                  Thanks for your help.
