0 Replies Latest reply on Mar 22, 2017 12:44 AM by JONNILIGHTNIN
    Business Catalyst Dreamweaver Template Issue
    JONNILIGHTNIN Level 1
      Hello,
      Ive been told that somehow the template I created in dreamweaver affects the css that controls BC modules, my site currently does not look like the one i created in DW althought I have upload the newest version. I have been playing ping pong between BC techs and DW and BC said that they cant help me with code, I hope you guys can assist me. Here is the code I have for the template. Please feel free to share your thoughts. thank you.
      <!DOCTYPE html>
      <html lang="en">
      <head>
      <meta charset="UTF-8">
      <meta http-equiv="X-UA-Compatible" content="IE=edge">
      <meta name="viewport" content="width=device-width, initial-scale=1"><meta name="author" content="IbarDesign">
      <!-- TemplateBeginEditable name="doctitle" -->
      <title>Veneto Luce | Home</title>
      <!-- TemplateEndEditable -->
      <link rel="shortcut icon" href="../images/_svg/Veneto_logo_solo_b.svg"/>
      <!-- Bootstrap -->
      <link href="/css/bootstrap.css" rel="stylesheet">
      <link href="/css/style.css" rel="stylesheet" type="text/css">
      <!-- HTML5 shim and Respond.js for IE8 support of HTML5 elements and media queries -->
      <!-- WARNING: Respond.js doesn't work if you view the page via file:// -->
      <!--[if lt IE 9]>
            <script src="https://oss.maxcdn.com/html5shiv/3.7.2/html5shiv.min.js"></script>
            <script src="https://oss.maxcdn.com/respond/1.4.2/respond.min.js"></script>
          <![endif]-->
      <!--The following script tag downloads a font from the Adobe Edge Web Fonts server for use within the web page. We recommend that you do not modify it.-->
      <script>var __adobewebfontsappname__="dreamweaver"</script>
      <script src="http://use.edgefonts.net/syncopate:n4:default.js" type="text/javascript"></script>
      </head>
      <body>
      <header class="header">
        <nav class="navbar navbar-default">
            <div class="container">
              <!-- Brand and toggle get grouped for better mobile display -->
              <div class="navbar-header">
                <button type="button" class="navbar-toggle collapsed" data-toggle="collapse" data-target="#defaultNavbar1" aria-expanded="false"><span class="sr-only">Toggle navigation</span><span class="icon-bar"></span><span class="icon-bar"></span><span class="icon-bar"></span></button>
                <a class="navbar-brand" href="../html/index.html" title="Veneto Luce"></a></div>
              <!-- Collect the nav links, forms, and other content for toggling -->
              <div class="collapse navbar-collapse" id="defaultNavbar1">
                <ul class="nav navbar-nav">
                  <li class="active"><a href="../html/index.html">HOME<span class="sr-only">(current)</span></a></li>
                  <li class="dropdown"><a href="#" class="dropdown-toggle" data-toggle="dropdown" role="button" aria-haspopup="true" aria-expanded="false">SHOP<span class="caret"></span></a>
                    <ul class="dropdown-menu">
                      <li><a href="http://www.venetoluce.com/veneto-luce-lighting ">LIGHTING</a></li>
                        <li><a href="../html/home-decor.html">DECOR</a></li>
                   <li><a href="http://www.venetoluce.com/veneto_luce_wholesale-sign-up.html">WHOLESALE</a></li>
                    </ul>
                  </li>
                   <li><a href="../html/about-us.html">ABOUT US</a></li>
                    <li><a href="">CONTACT US</a></li>
                    <li><a href="">LOG-IN</a></li>
                    <form name="catsearchform59779" method="post" action="../search-results.html"><div class="search-box"><input class="cat_textbox_small" type="text" name="CAT_Search" id="CAT_Search" /><input class="cat_button" type="submit" value="Search" /></div></form>
                </ul>
              </div>
              <!-- /.navbar-collapse -->
          </div>
            <!-- /.container-fluid -->
        </nav>
      </header>
      <!-- TemplateBeginEditable name="content" -->content<!-- TemplateEndEditable -->
      <!-- footer -->
      <footer class="footer">
        <div class="row">
            <div class="col-lg-4">
                <div id="menu">
                <ul>
                <li class="heading">LIGHTING</li>
                <li><a href="http://www.venetoluce.com/veneto-luce-lighting/ceiling-lighting" title="Ceiling Lighting">CIELING</a></li>
                <li><a href="http://www.venetoluce.com/veneto-luce-lighting/wall-lighting" title="Wall Lighting">WALL</a></li>
                <li><a href="http://www.venetoluce.com/veneto-luce-lighting/floor-lighting" title="Floor Lighting">FLOOR</a></li>
            </ul>
                </div>
            </div>
                <div id="contact info">
                <a href="https://www.facebook.com" target="_blank" title="Veneto Luce Facebook" ><img id="social-media-veneto" src="../images/_social_icons/white/veneto_luce_fb_w.svg" alt="veneto luce instagram" href="facebook.com"/></a>
                <a href="https://www.twitter.com" target="_blank" title="Veneto Luce Twitter"><img id="social-media" src="../images/_social_icons/white/veneto_luce_tw_w.svg" alt=""/></a>
            <a href="https://www.instagram.com" target="_blank" title="Veneto Luce Instagram"><img id="veneto-luce-instagram" src="../images/_social_icons/white/veneto_luce_ig_w.svg" alt=""/></a>
              </div>
              <div id="veneto luce address">
                  <h5 class="address">490 s. san vicente blvd. #8 </h5>
                  <h5 class="address">west hollywood, ca. 90048</h5>
                </div>
              <div id="veneto luce phone">
                  <h3 id="phone"><a href="tel:+14243334511" title="Veneto Luce Phone Number">424-333-4511
                <span class="sr-only">phone number contact</span></a></h3>
              </div>
          </div>
                <div id="veneto links">
                <ul>
                <li class="heading">VENETO LUCE</li>
                <li><a href="../html/return-policy.html">RETURN POLICY</a></li>
            </ul>
                </div>
            </div>
        </div>
      </footer>
      <!-- jQuery -->
      <!-- <script src="js/jquery.js"></script> -->
      <script src="../js/jquery-1.11.3.min.js"></script>
      <!-- Bootstrap Core JavaScript -->
      <script src="../js/bootstrap.min.js"></script> <!-- Script to Activate the Carousel -->
      <script>
          $('.carousel').carousel({
              interval: 5000 //changes the speed
          </script>
      </body>
      </html>
