• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Why do Arrays like allPageItems, allTextFrames etc. not reflect index number properties?
Explorer ,
Mar 22, 2017 Mar 22, 2017
Hi there,
I am currently trying to implement a tool for inspecting all sorts of data types and their properties using the reflect() method. While playing around with the reflection results, I noticed that normal Arrays return number index properties (0, 1, 2 etc.) as one would expect, but for some reason special Arrays that hold all items of a container, like allPageItems, allTextFrames etc. do not contain these number properties, although they appear to have a length greater than 0.
See this example:
// @target InDesign
var testArray = ["foo", "bar", "baz"];
$.writeln(testArray);                           // --> foo,bar,baz
$.writeln(testArray.length);                    // --> 3
$.writeln(testArray.reflect.properties);        // --> 0,1,2,length,__proto__
$.writeln("-----------------------");
var doc = app.documents.add();
doc.rectangles.add();
doc.textFrames.add();
doc.ovals.add();
$.writeln(doc.zeroPoint);                       // --> 0,0
$.writeln(doc.zeroPoint.length);                // --> 2
$.writeln(doc.zeroPoint.reflect.properties);    // --> 0,1,length,__proto__
$.writeln(doc.allPageItems);                    // --> [object Oval],[object TextFrame],[object Rectangle]
$.writeln(doc.allPageItems.length);             // --> 3
$.writeln(doc.allPageItems.reflect.properties); // --> length,__proto__
As you can see the last array (allPageItems returns a length of three, but does not return properties like 0, 1, 2, unlike the other Arrays.
Does anyone know why that is? Would be great, if I could just make use of reflection as I can with the normal Arrays.
Thanks for your help!
TR
P.S.: InDesign CS6, OS X 10.8.5.
TOPICS
Scripting
Views
841
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast , Mar 22, 2017 Mar 22, 2017
var coll = app.activeDocument.allPageItems
var arr = Array.prototype.slice.call( coll, 0 );
quickNdirty to convert collections to arrays
Votes
Translate
Translate
Advisor ,
Just a wild guess here, but those "allPageItems" and all are not Js arrays but array-like objects returned by the underlying C++ code in Indesign. They are basically "uninitialised" by the JS engine.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Votes
Translate
Translate
Report
Report
Advisor ,
var testarray=app.activeDocument.allPageItems;
$.writeln(testarray.reflect.properties);        // --> length,__proto__
testarray=Array.prototype.slice.call( testarray, 0 );
$.writeln(testarray.reflect.properties);        // --> 0,1,2,length,__proto__
-hans-: AWESOME
Votes
Translate
Translate
Report
Report
Explorer ,
Great workaround Hans, works like a charm. Thank you very much!
Regards,
TR
Votes
Translate
Translate
Report
Report
Guide ,
Mar 27, 2017 Mar 27, 2017
LATEST
Hi colleagues,
My two pennies:
var a = [].concat(app.activeDocument.allPageItems);
instantly set a clean Array that will pass the reflect test as well.
Anyway, it's worth pointing out that a=app.activeDocument.allPageItems already is an Array object, not a collection. There is likely a bug in a.reflect.properties—in the sense MasterDomino illustrated—, but one can check that:
• a.constructor===Array,
• a.reflect.methods returns all methods we expect from an Array.
So, unless your script actually involves the Reflection object, you can handle app.activeDocument.allPageItems as such, it is indeed an array.
Marc
Votes
Translate
Translate
Report
Report
