1 Reply Latest reply on Mar 26, 2017 10:55 AM by c.pfaffenbichler
    Create Gradients with Custom Step Number & Color via PS Scripting
    arteangelus Level 1
      Hello,
      I'm trying to make a new gradient which should be added in gradient preset manager. I would like add more user defined gradient steps and unique colors.
      Using xbytors action to javascript tool I was able to create script (at the bottom of post.) But as it gets so complex for more steps controlling them become harder, so I thought there should be a way to put following lines under a function...(I noticed that those are the lines for defining rgb color and location, and it repeating as I add more steps..)
       var desc4 = new ActionDescriptor();
          var desc5 = new ActionDescriptor();
          desc5.putDouble(cTID('Rd  '), 0);
          desc5.putDouble(cTID('Grn '), 0);
          desc5.putDouble(cTID('Bl  '), 0);
          desc4.putObject(cTID('Clr '), sTID("RGBColor"), desc5);
          desc4.putEnumerated(cTID('Type'), cTID('Clry'), cTID('UsrS'));
          desc4.putInteger(cTID('Lctn'), 0);
          desc4.putInteger(cTID('Mdpn'), 50);
          list1.putObject(cTID('Clrt'), desc4);
      I tried to convert it to a function like this; ( Should I give desc5,desc4 variables unique names? )
      function addgradientstep(redcolor,greencolor,bluecolor,location) {
          desc5.putDouble(cTID('Rd  '), 0); // Red Color
          desc5.putDouble(cTID('Grn '), 0); // Green Color
          desc5.putDouble(cTID('Bl  '), 0); // Blue Color
          desc4.putInteger(cTID('Lctn'), 0); // Gradient Step Location
      And I thought I would call them like; ( I don't need to do anything with transparency options by the way, only color steps...) ( It gave an error at this line ;
      step1();
      addgradientstep(255,255,255,0);
      addgradientstep(0,0,0,25);
      addgradientstep(128,128,128,50);
      step2();
      Full script;
      #target photoshop
      cTID = function(s) { return app.charIDToTypeID(s); };sTID = function(s) { return app.stringIDToTypeID(s); };
      var steps = 10;
      function Simple_Gradient() {
          var desc1 = new ActionDescriptor();
          var ref1 = new ActionReference();
          ref1.putClass(cTID('Grdn'));
          desc1.putReference(cTID('null'), ref1);
          var desc2 = new ActionDescriptor();
          var desc3 = new ActionDescriptor();
          desc3.putString(cTID('Nm  '), "GradientName");
          desc3.putEnumerated(cTID('GrdF'), cTID('GrdF'), cTID('CstS'));
          desc3.putDouble(cTID('Intr'), 4096);
          var list1 = new ActionList();
          var desc6 = new ActionDescriptor();
          var desc7 = new ActionDescriptor();
          desc7.putDouble(cTID('Rd  '), 255);
          desc7.putDouble(cTID('Grn '), 255);
          desc7.putDouble(cTID('Bl  '), 255);
          desc6.putObject(cTID('Clr '), sTID("RGBColor"), desc7);
          desc6.putEnumerated(cTID('Type'), cTID('Clry'), cTID('UsrS'));
          desc6.putInteger(cTID('Lctn'), 4096);
          desc6.putInteger(cTID('Mdpn'), 50);
          list1.putObject(cTID('Clrt'), desc6);
          desc3.putList(cTID('Clrs'), list1);
          var list2 = new ActionList();
          var desc8 = new ActionDescriptor();
          desc8.putUnitDouble(cTID('Opct'), cTID('#Prc'), 100); // Start Opacity
          desc8.putInteger(cTID('Lctn'), 0); // Location
          desc8.putInteger(cTID('Mdpn'), 50); // Mid Point
          list2.putObject(cTID('TrnS'), desc8);
          var desc9 = new ActionDescriptor();
          desc9.putUnitDouble(cTID('Opct'), cTID('#Prc'), 38.0392156862745); // End Opacity
          desc9.putInteger(cTID('Lctn'), 4096); // Location
          desc9.putInteger(cTID('Mdpn'), 50); // Mid Point
          list2.putObject(cTID('TrnS'), desc9);
          desc3.putList(cTID('Trns'), list2);
          desc2.putObject(cTID('Grad'), cTID('Grdn'), desc3);
          desc1.putObject(cTID('Usng'), cTID('Grdn'), desc2);
          executeAction(cTID('Mk  '), desc1, DialogModes.NO);
      Simple_Gradient();
      // for (i = 0; i < steps; i++){}
      Thank you,
      Best Regards.
        • 1. Re: Create Gradients with Custom Step Number & Color via PS Scripting
          c.pfaffenbichler Level 9
          Does this help?
          // 2017, use it at your own risk;
          #target photoshop
          var theGradient = gradientLayer([[0,0,0,0], [1000,128,128,255], [2000,255,255,0]]);
          function gradientLayer(theArray) {
          var idClr = charIDToTypeID( "Clr " );
          var idRd = charIDToTypeID( "Rd  " );
          var idGrn = charIDToTypeID( "Grn " );
          var idBl = charIDToTypeID( "Bl  " );
          var idRGBC = charIDToTypeID( "RGBC" );
          var idLctn = charIDToTypeID( "Lctn" );
          var idMdpn = charIDToTypeID( "Mdpn" );
          var idOpct = charIDToTypeID( "Opct" );
          var idPrc = charIDToTypeID( "#Prc" );
          var idTrnS = charIDToTypeID( "TrnS" );
          var idType = charIDToTypeID( "Type" );
          var idMk = charIDToTypeID( "Mk  " );
              var desc10 = new ActionDescriptor();
              var idnull = charIDToTypeID( "null" );
                  ref1.putClass( idcontentLayer = stringIDToTypeID( "contentLayer" ) );
              desc10.putReference( idnull, ref1 );
              var idUsng = charIDToTypeID( "Usng" );
                  var desc11 = new ActionDescriptor();
                      var desc12 = new ActionDescriptor();
                      desc12.putBoolean( charIDToTypeID( "Dthr" ), true );
                      desc12.putUnitDouble( charIDToTypeID( "Angl" ), charIDToTypeID( "#Ang" ), 0.000000 );
                      desc12.putEnumerated( idType, charIDToTypeID( "GrdT" ), charIDToTypeID( "Lnr " ) );
                      var idGrad = charIDToTypeID( "Grad" );
                          var desc13 = new ActionDescriptor();
                          var idNm = charIDToTypeID( "Nm  " );
                          desc13.putString( idNm, "Custom" );
                          var idGrdF = charIDToTypeID( "GrdF" );
                          desc13.putEnumerated( idGrdF, idGrdF, charIDToTypeID( "CstS" ) );
                          var idIntr = charIDToTypeID( "Intr" );
                          desc13.putDouble( idIntr, 4096.000000 );
          // insert color stops;
          for (var m = 0; m < theArray.length; m++) {
          var desc14 = new ActionDescriptor();
          var desc15 = new ActionDescriptor();
          desc15.putDouble( idRd, theArray[m][1] );
          desc15.putDouble( idGrn, theArray[m][2] );
          desc15.putDouble( idBl, theArray[m][3] );
          desc14.putObject( idClr, idRGBC, desc15 );
          var idClry = charIDToTypeID( "Clry" );
          var idUsrS = charIDToTypeID( "UsrS" );
          desc14.putEnumerated( idType, idClry, idUsrS );
          desc14.putInteger( idLctn, theArray[m][0] );
          desc14.putInteger( idMdpn, 50 );
          var idClrt = charIDToTypeID( "Clrt" );
          list1.putObject( idClrt, desc14 );
                          desc13.putList( charIDToTypeID( "Clrs" ), list1 );
                          var idTrns = charIDToTypeID( "Trns" );
                                  var desc18 = new ActionDescriptor();
                                  desc18.putUnitDouble( idOpct, idPrc, 100.000000 );
                                  desc18.putInteger( idLctn, 0 );
                                  desc18.putInteger( idMdpn, 50 );
                              list2.putObject( idTrnS, desc18 );
                                  var desc19 = new ActionDescriptor();
                                  desc19.putUnitDouble( idOpct, idPrc, 100.000000 );
                                  desc19.putInteger( idLctn, 100 );
                                  desc19.putInteger( idMdpn, 50 );
                              list2.putObject( idTrnS, desc19 );
                          desc13.putList( idTrns, list2 );
                      var idGrdn = charIDToTypeID( "Grdn" );
                      desc12.putObject( idGrad, idGrdn, desc13 );
                  desc11.putObject( idType, stringIDToTypeID( "gradientLayer" ), desc12 );
              desc10.putObject( idUsng,  stringIDToTypeID( "contentLayer" ), desc11 );
          executeAction( idMk, desc10, DialogModes.NO );
          return activeDocument.activeLayer
