5 Replies Latest reply on Mar 23, 2017 6:07 AM by Gutterfish
    Expression Cluster, Zero out 540 slider
    alexanderk38549755 Level 1
      Like you can see, I have a null object where I have stored some sliders which is hooked/pickwhipped to some shape layers to be able to control the more easily. My problem is how to change the sliders value to 0 while keeping the actual (540) value. I want to make the position where they are now 0 and be able to drag it to make the shape layer go upwards.
      Shape layer is connected to null slider and can only move on the y-axis with the expressions I have set up:
      temp = thisComp.layer("Control").effect("Slider Control 2")("Slider");
      [value[0], temp]
      If you were wondering.
      Sorry if its confusing.
      (Discussion successfully moved from The Lounge to After Effects)
