5 Replies Latest reply on Nov 10, 2017 3:25 PM by alexandriar92172436
    error in installing phonegap
    sethup51656429 Level 1
      C:\Users\SETHU>npm version
      { npm: '3.10.10',
        ares: '1.10.1-DEV',
        http_parser: '2.7.0',
        icu: '58.2',
        modules: '48',
        node: '6.10.1',
        openssl: '1.0.2k',
        uv: '1.9.1',
        v8: '5.1.281.95',
        zlib: '1.2.8' }
      C:\Users\SETHU>git
      usage: git [--version] [--help] [-C <path>] [-c name=value]
                 [--exec-path[=<path>]] [--html-path] [--man-path] [--info-path]
                 [-p | --paginate | --no-pager] [--no-replace-objects] [--bare]
                 [--git-dir=<path>] [--work-tree=<path>] [--namespace=<name>]
                 <command> [<args>]
      These are common Git commands used in various situations:
      start a working area (see also: git help tutorial)
         clone      Clone a repository into a new directory
         init       Create an empty Git repository or reinitialize an existing one
      work on the current change (see also: git help everyday)
         add        Add file contents to the index
         mv         Move or rename a file, a directory, or a symlink
         reset      Reset current HEAD to the specified state
         rm         Remove files from the working tree and from the index
      examine the history and state (see also: git help revisions)
         bisect     Use binary search to find the commit that introduced a bug
         grep       Print lines matching a pattern
         log        Show commit logs
         show       Show various types of objects
         status     Show the working tree status
      grow, mark and tweak your common history
         branch     List, create, or delete branches
         checkout   Switch branches or restore working tree files
         commit     Record changes to the repository
         diff       Show changes between commits, commit and working tree, etc
         merge      Join two or more development histories together
         rebase     Reapply commits on top of another base tip
         tag        Create, list, delete or verify a tag object signed with GPG
      collaborate (see also: git help workflows)
         fetch      Download objects and refs from another repository
         pull       Fetch from and integrate with another repository or a local branch
         push       Update remote refs along with associated objects
      'git help -a' and 'git help -g' list available subcommands and some
      concept guides. See 'git help <command>' or 'git help <concept>'
      to read about a specific subcommand or concept.
      C:\Users\SETHU>npm -g install phonegap@latest
      npm WARN deprecated tough-cookie@2.2.2: ReDoS vulnerability parsing Set-Cookie h
      ttps://nodesecurity.io/advisories/130
      npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
      npm WARN deprecated node-uuid@1.4.7: Use uuid module instead
      C:\Users\SETHU\AppData\Roaming\npm
      `-- (empty)
      npm ERR! Windows_NT 6.1.7600
      npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\
      node_modules\\npm\\bin\\npm-cli.js" "-g" "install" "phonegap@latest"
      npm ERR! node v6.10.1
      npm ERR! npm  v3.10.10
      npm ERR! path C:\Users\SETHU\AppData\Roaming\npm\node_modules\.staging\abbrev-b9
      8de9ba
      npm ERR! code ENOENT
      npm ERR! errno -4058
      npm ERR! syscall rename
      npm ERR! enoent ENOENT: no such file or directory, rename 'C:\Users\SETHU\AppDat
      a\Roaming\npm\node_modules\.staging\abbrev-b98de9ba' -> 'C:\Users\SETHU\AppData\
      Roaming\npm\node_modules\phonegap\node_modules\npm\node_modules\abbrev'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! Please include the following file with any support request:
      npm ERR!     C:\Users\SETHU\npm-debug.log
      npm ERR! code 1
      C:\Users\SETHU>
      as you can see above i have installed both GIT and NODE.JS for phonegap .But is this?
      i'm using windows 7 64 bit
