• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Disable editText when DropDownList selected
Community Beginner ,
Mar 23, 2017 Mar 23, 2017
Hi everyone!
I'm trying to write my first script. I don't know how to disable my EditText when select one item in DropDownList.
Anyone can help me out with it?
sorry about my english. thanks a lot!
here is the script UI
function createUserInterface (thisObj,userInterfaceString,scriptName){
    var pal = (thisObj instanceof Panel) ? thisObj : new Window("palette", scriptName,
  undefined,{resizeable: true});
    if (pal == null) return pal;
    var UI=pal.add(userInterfaceString);
          UI.myTabbedPanel.tabPoint.myGroup1.PointDropDownList.selection = 1;
    pal.layout.layout(true);
    pal.layout.resize();
    pal.onResizing = pal.onResize = function () {
        this.layout.resize();
    if ((pal != null) && (pal instanceof Window)) {
            pal.show();
    return UI;
var resourceString =
"group{orientation:'column', alignment:['fill', 'fill'], alignChildren:['left', 'top'],\
                     myIconButton: IconButton{text:'My website', image:'~/Desktop/logo/icon2.jpg'},\
                     myTabbedPanel: Panel{type:'tabbedpanel', orientation:'left', alignChildren:['left', 'fill'],\
                           tabPoint: Panel{type:'tab', text:'Point', orientation:'column',alignment:['left','top'],\
                                myGroup1: Group{orientation:'row', alignment:['left','top'],\
                                    myStaticText: StaticText{text:'Select Point Number'},\
                                    PointDropDownList: DropDownList{properties:{items:['1 Point', '2 Points','3 Points', '4 Points', '5 Points', '6 Points']}},\
                                myGroup2: Group{orientation:'row', alignment:['left','top'],\
                                    myGroupPointRow1: Group{orientation:'column', alignment:['left','top'],\
                                        myEditTextPoint1: EditText{text:'Cut 1 Point ', alignment:['left','top'], characters:11},\
                                        myEditTextPoint3: EditText{text:'Cut 3 Point ', alignment:['left','top'], characters:11},\
                                        myEditTextPoint5: EditText{text:'Cut 5 Point ', alignment:['left','top'], characters:11},\
                                    myGroupPointRow2: Group{orientation:'column', alignment:['left','top'],\
                                        myEditTextPoint2: EditText{text:'Cut 2 Point ', alignment:['left','top'], characters:11},\
                                        myEditTextPoint4: EditText{text:'Cut 4 Point ', alignment:['left','top'], characters:11},\
                                        myEditTextPoint6: EditText{text:'Cut 6 Point ', alignment:['left','top'], characters:11},\
                                myGroup3: Group{orientation:'row', alignment:['left','top'],\
                                    myCheckbox: Checkbox{text:'Keep your layer selection'},\
                         tabMarker: Panel{type:'tab', text:'Marker', orientation:'column',\
                myButton2: Button{text:'Apply', alignment:['right','buttom']},\
var UI = createUserInterface(this,resourceString,"Trim Layers");
// I have tried this, but error
UI.myGroup.myTabbedPanel.tabPoint.myGroup1.PointDropDownList.selection[2].onClick = function () {
       UI.myGroup.myTabbedPanel.tabPoint.myGroup2.myGroupPointRow1.myEditTextPoint1.enabled = !this.value;
TOPICS
Scripting
Views
420
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast ,
Here's a simplified example that should help you out:
     var pal = (thisObj instanceof Panel) ? thisObj : new Window("palette", scriptName, undefined,{resizeable: true});
     pal.grp =pal.add(resourceString);
     pal.grp.PointDropDownList.onChange = function() {
          pal.grp.myEditTextPoint1.enabled = (this.selection.index != 2) // i.e. enabled if 3 Points isn't selected
          pal.show();
     return UI;
Votes
Translate
Translate
Report
Report
thanks for the quick response. It worked
Votes
Translate
Translate
Report
Report
Mar 24, 2017 Mar 24, 2017
I tried but It didn't work work for all 3  (1 Point, 2 Points, 3 Points)
1 Point: enabled All   (No)
2 Points: enable "cut 1 Point" "cut 2 Point" (No)
3 Points: enable only "cut 3 Point" (YES)
I don't know any syntax to fix this error. Can you help me one more?
    var UI = pal.add(userInterfaceString);
          UI.myTabbedPanel.tabPoint.myGroup1.PointDropDownList.onChange = function () {
                  UI.myTabbedPanel.tabPoint.myGroup2.myGroupPoint.myEditTextPoint2.enabled = (this.selection.index != 0)
                  UI.myTabbedPanel.tabPoint.myGroup2.myGroupPoint.myEditTextPoint3.enabled = (this.selection.index != 0)
                  UI.myTabbedPanel.tabPoint.myGroup2.myGroupPoint.myEditTextPoint1.enabled = (this.selection.index != 1)
                  UI.myTabbedPanel.tabPoint.myGroup2.myGroupPoint.myEditTextPoint3.enabled = (this.selection.index != 1)
                  UI.myTabbedPanel.tabPoint.myGroup2.myGroupPoint.myEditTextPoint1.enabled = (this.selection.index != 2)
                  UI.myTabbedPanel.tabPoint.myGroup2.myGroupPoint.myEditTextPoint2.enabled = (this.selection.index != 2)
            pal.show();
    return UI;
                                    PointDropDownList: DropDownList{properties:{items:['1 Point', '2 Points','3 Points']}},\
                                    myGroupPoint: Group{orientation:'column', alignment:['left','top'],\
Votes
Translate
Translate
Report
Report
Enthusiast ,
LATEST
I don't even have to really study this to see it's a flaw in your logic, not the syntax. You've got multiple lines that specifically set each textbox's enabled setting so its only the last one that will stick.
You can either do something like:
myEditTextPoint1.enabled = (THIS CONDITION && THIS CONDITION);
myEditTextPoint2.enabled = (THIS CONDITION && THIS CONDITION);
You set enabled through true/false so it's just whether the resulting conditions are true/false.
or
if (this.selection.index == 0) {
     myEditTextPoint1.enabled = true;
     myEditTextPoint2.enabled = false;
} else if (this.selection.index == THIS) {
     DO ALL THESE THINGS INSTEAD
} else {
Obviously this code is just an example for explanation and you'll have to fill it in properly. Figuring out logic is an important part of learning to code.
Votes
Translate
Translate
Report
Report
