• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
"View" checkbox missing when using .AVI file
New Here ,
Mar 23, 2017 Mar 23, 2017
As the title, I was using AE cs6 and I found that when I drag .avi file into composition, the "view" checkbox just disappear.
It end up only showing black background in both preview & render output. After I found this problem I tried import .mov file or jpeg and both seem normal.
So now I know the problem now is I can't turn on the "view" for .avi file but after I checked through the settings & forums I just can't find anyway to solve this.Untitled.png
Attached herewith the sample of my AE, as we can see I tried import different .avi files but it both unable to view in AE while other files can.
** The mov file is the previous composition also make from raw .avi file but at the second day my AE suddenly unable to view .avi anymore...
Views
1.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Mar 23, 2017 Mar 23, 2017
You need to transcode the problem file.  You can tell from the screen shot that there is no codec displayed -- just the fact that it is an AVI.  This means AE can not read the codec of this file.
Find an application that will read the codec and transcode it for use in AE.
Votes
Translate
Translate
Enthusiast ,
I see that the checkbox is missing.  I think of it more that it's not that it's missing but rather, AE is not recognizing this .avi as a video file or something and if not, then it will not show that check box.
Much like, sometimes I've imported footage that I thought had audio and the audio check does not appear.  Usually, that meant there was a problem and it did not contain audio.  In your two files, however I DO see that audio seems available.
1.  Does the audio work?
2.  Are you able to open this avi file in Premiere and see video?
Clearly it is not recognizing video - in my opinion.
Eric
Votes
Translate
Translate
Report
Report
New Here ,
Mar 24, 2017 Mar 24, 2017
LATEST
Yes the audio does work. I only realize the file got problem after I finish render and the video is all black with audio. (I just want to change the file into mov so I can resize it & no edit.)
Guess it had the problem like Dave said but now I had found the other way to do that so guess I will just give up the AE for now lol.
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
