I want to import a file into a exact time, basically where my timeline/timemark is. is there any shortcut?
[Moved from Lounge to After Effects based on previous activity... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
you import the file to your project panel, then you can use Ctrl+/ to place the footage element in your active composition. you can then use open bracket shortcut [ to move the layer to the CTI - this is the default behavior. you can also un-check preferences->general->create layer at composition start time, and then you can use Ctrl+/ to place it directly at the CTI without the second shortcut.
This is not a product forum. You've posted in the non-technical Lounge. A forum moderator can move this to the right place for you. Please tell us which software you're using.
