Hey
I have a 3 monitor setup which I've been successfully using with monitor 3 enabled for Mercury Transmit, with full screen preview.
Then I upgraded monitor 2 to a UHD resolution monitor and now Mercury Transmit won't work properly - enabling it for monitor 3 puts the preview on monitor 2, much smaller than full screen. Likewise enabling it for monitor 1.
I have the text size on my UHD monitor set to 150%, but even when I set that back to 100% it doesn't solve the Mercury Transmit issue, and also makes it really hard to see any text.
So bummed that this is like this... almost considering moving back to my old monitor.
Bueller.... Bueller....
Is your display card capable of 4K output? I have an older Nvidia Quadro 5000 card and max rez is 1920X1080.
One thing I could recommend is to not use the GPU for full screen playback. Instead, use a proper I/O device from AJA, Blackmagic, etc.
I also have a 3-monitor setup running GTX 2080ti. My main middle monitor is now a 4k with two 2k on either side. My preview being on the right (see pic). Nvidia drivers are up to date
Mercury will run fine for about 5-ish minutes then the preview monitor image will freeze. When I toggle Mercury on/off it refreshes to a black screen. When I toggle on/off again it comes back with the original static image. I have to exit and re-start AE. It then works fine for 5-ish minutes, etc., etc.
