7 Replies Latest reply on Mar 27, 2017 1:13 AM by davescm
    Colour picker tool setting background
    Rob A1
      As I scroll over the colour swatches the picker tool will set the background colour.
      Also ALT over an image to select a colour sets the background colour.
      As stands I have to X to or arrow between backround foreground to reverse foreground/background before using paintbrush, flood tool etc.
      I believe I might have inadvertently set the background as the active layer? or have I somehow toggled the picker to set background?
      How do I get the picker to revert to setting Foreground colour?
      I have jiggled around in the colour palate and found a warning triangle.
      I dont know what I did but the picker tool reverted to setting the foreground layer.... or made the foreground active so the picker wrote to that?
      So I have blundered out of the problem but I'm completely clueless and there is probably a simple process that I should understand.
      I use a lot of SHIFT and CTRL-a,s,d,z,x,c,v, a lot of ALT select and do it pretty quickly. I think I probably ham fingered something.
      I would really appreciate an explanation.
        • 1. Re: Colour picker tool setting background
          davescm Adobe Community Professional
          Hi
          I moved your post to the Photoshop forum.
          Simple fix - In the Color panel click on the foreground square
          Dave
          • 2. Re: Colour picker tool setting background
            Rob A1 Level 1
            Thanks Dave. Simple. Nightmare if you dont know about it.
            Only in Essentials workspace, not in painting, photo, or the other workspaces.
            I read somewhere about Backround/Foreground fixed as active, but couldnt find anything that would toggle it. Anything in that?
            • 3. Re: Colour picker tool setting background
              So true of many things in Photoshop
              Sorry I'm not sure what you mean there. You can toggle the background and foreground colours at any time by clicking on the switch colours icon in the toolbar but I don't think that is what you meant?
              Dave
              • 4. Re: Colour picker tool setting background
                Rob A1 Level 1
                Thanks Dave, really appreciated the help. To be honest even though I reset to foreground, I didnt know what it was that I had done or tapped with the wacom that had toggled it back to the normal setting.
                No formal training here so I fall into holes sometimes that do my head in.
                I understand paint is applied to the active foreground/background. The picker tool selects from the active foreground/background. Colour replacement brush, clone brush etc.
                Even though I could toggle between the foreground background colours (see below) in the picker tool it didnt set whether the picked colour applied foreground or background.
                • 5. Re: Colour picker tool setting background
                  Ok
                  So for clarity
                  Your brush will paint with the foreground colour and, on a background layer, the eraser will paint with the background colour (on other layers the eraser deletes.
                  The colour picker will pick either the foreground or the background depending on which square you click before using it.
                  So click here :
                  and foreground picker opens
                  Click here :
                  and background color picker opens
                  Just clicking with the eye dropper will set foreground or background according to the last use of the color picker tool as above i.e. once set to pick background colours it will stay set that way until you set it to pick the foreground.
                  I hope that helps
                  Dave
                  • 6. Re: Colour picker tool setting background
                    Rob A1 Level 1
                    Dave you might have to check that. If you have your Color Panel clicked on the background, regardless of selecting the foreground background colour to be sampled by the picker as in your last post, it might still put that swatch into the background, meaning you had to again "x" or arrow switch foreground backround swatch in the toolbar. That was what was doing me in for ages. Unless I have some sort of harware confilct with my Wacom v Photoshop, I have to go to the colour panel (in essentials) as in your original post and make sure I have Foreround swatch toggled on.
                    For me, the color picker dialogue box only toggles whether I sample foreground or background, not whether the brush is set to foreground or backround swatch.
                    • 7. Re: Colour picker tool setting background
                      That is the correct behaviour
                      Dave
