• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
how do I "save as" to recent folders
Community Beginner ,
Mar 26, 2017 Mar 26, 2017
I've looked in the file handling preferences and I don't see an option to add this to the favorites. I just want to "save as" and have the last folder I was in to come up so I don't have to navigate through all the files again.
Thanks!
Views
5.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Mar 26, 2017 Mar 26, 2017
There is a Preference setting to "save as to original folder". If you uncheck this it will remember the last folder used.
Votes
Translate
Translate
Adobe
Community Expert ,
Your statement does not seem completely clear to me.
In any case on Mac you should be able to select one of the recent Folders from a dropdown menu:
Votes
Translate
Translate
Report
Report
That did it! Thank you so much!
Votes
Translate
Translate
Report
Report
Yes, I could find the folder in my documents, but I just didn't want to have to go through and select the various sub folders every time. D Fosse's response worked for what I needed. Thank you so much!
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
May 29, 2018 May 29, 2018
I will appreciate it if someone could give more details about this solution. I went through the entire preferences of Adobe Acrobat Pro XI and couldn't find it. Does it apply only to later versions? Thank you.
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 25, 2022 Nov 25, 2022
LATEST
"Save as in original folder" is only in the Photoshop prefs.  I have yet to test this but I think what is best and what most designers want here is, Saving a file in Photoshop or Ilustatator.  Then when pasting in InDesign, it opens that last folder with the newly edited/saved file in the finder... done.  Is this what will happen when deselecting the "save as in original file" turned off?  This always seems to be a problem and I see the folder that opens on my Mac when placing is delayed for opening the latest folder I saved to. It does change however... after time?  I have not documented this closely enough yet to understand why.  There is a setting in Finder prefs on a Mac.. "New Finder windows show:"  I have that set at recents.
Votes
Translate
Translate
Report
Report
