1 Reply Latest reply on Mar 26, 2017 1:16 PM by Test Screen Name
    optimization
    naelekyab32905128
      I need to remove optimization from my image, I cant find out how to remove it. I see the original in the save for web window, but now way to revert
        • 1. Re: optimization
          When you choose Save for Web, your open PSD file doesn't change. Also your PSD file on disk doesn't change.
          Instead, it shows you the original file (as it is) and the optimized file (if you were to save for web, then reopen).
          I suspect you may think you have done some damage to the file. You won't, unless you use Save for Web and somehow destroy your original file.
