had this problem some time ago - now it's back ...
when i scann a color copy, acrobat rotates the orientation with about 45 degree.
do i the same with a black-and-white scann (the same sheet) it scanns correct.
everything is up to date, just started windows 10 64bit again - same problem.
Please uncheck "Recognize Text(OCR)" checkbox once from scan setting window and scan.
Thanks.
it worked once when I saved the settings with OCR and then without. but after that, nomatter what I did, it screwed up the scann. please correct the programm. thx
an by the way, the gui is still awful! there was once a time, when i could just klick on the icon an acrobat made a scann - bw, color, etc. as the icon.
acrobat is a very simple programm and has not so many options, so why the hell is there such a poor gui?! on 24 inch sreen you have so much space, you could place almost all options on it ... i often have the feeling, you guys dont work with your programms.
