4 Replies Latest reply on Mar 26, 2017 9:03 PM by jamesb21679646
    Conditional formatting - image
      How can I populate an image based on conditional formatting?
      I am making an patient results form and based on each questions score I want to populate an answer that is both copy and an image. Right now I have the following code that is providing the copy answer:
      var Deepsquat = this.getField("Deepsquat").value;
      var Pain = this.getField("Pain").value;
      var Red = this.getField("Red").value;
      var Yellow = this.getField("Yellow").value;
      var Green = this.getField("Green").value;
      if (Deepsquat == "0") event.value = Pain;
      if (Deepsquat == "1") event.value = Red;
      if (Deepsquat == "2") event.value = Yellow;
      if (Deepsquat == "3") event.value = Green;
      How do create a corresponding image to populate along with their answer? Can I do this in a text box with the custom calculation script or is there another place to input the appropriate code?
      Thank you.
        • 1. Re: Conditional formatting - image
          You can create a set of button fields with the images as their icons and then show/hide those buttons based on the value entered by the user. By the way, if you only want the user to enter specific values (0-3, for example) you should use a drop-down field instead of a text field. You can still use the same validation script, though.
          • 2. Re: Conditional formatting - image
            jamesb21679646 Level 1
            Thank you for the quick response and as such I am wondering if you can point me in a direction on how to use the button fields correctly. I know how to add the images to the button fields, but how and where do I enter the show/hide commands based on value. Do I need to enter this into the actions tab and show/hide field or run a javascript? And what's the right code needed? I see a lot of options on different forms and nothing seems to be working for me.
            • 3. Re: Conditional formatting - image
              You need to use JS, because it's conditional on the value of the other fields.
              You can integrate the code into your existing code. Let's say you have a button field called "PainImage" and you want to show it when the Deepsquat field equals zero. You can add this code to your existing code:
              this.getField("PainImage").display = (Deepsquat == "0") ? display.visible : display.hidden;
              Repeat the same for the other image fields, and it should work as you've described.
              • 4. Re: Conditional formatting - image
                This worked perfect, thank you very much!
