How do I load a Captivate 8 project to SharePoint 365 - the server not the LMS?
OK. Well that's weird but not impossible for these forums.
Here is the information pasted from that other thread.
A. Yes!
While there are articles on the web about using Flash output (SWF) in SharePoint, this note assumes HTML5 output from Captivate.
Are you talking about loading the CPTX project file to Sharepoint to backup the project file? Or are you talking about loading the HTM/SWF or HTML5 output to Sharepoint to deliver the content to end users?
Hi
I am talking about loading the HTM/SWF or HTML5 output to Sharepoint to deliver the content to end users
Take a look at this thread:
unfortunately I get an unauthorized message when I attempt to access the thread
Try logging out and logging in again with your Adobe ID.
Sorry Rod,
I have logged out and back in and still get the message
Access to this community or content is restricted. If you think this is a mistake, please contact your administrator or the person who directed you here.
A. Yes!
Thank you - this does the trick!
Did these steps work for anyone? When I follow them and then click on the newly titled index file (title.aspx) I just get a spinning window, but the content never opens. I was under the impression that was because SharePoint only looks at individual files, not files included in a folder, which is what the index file does....or do I have this misunderstood?
I am having the same issue, I am getting a spinning window too. Can someone assist?
Is there a work-around for SharePoint Online (part of Office 365) in the cloud?
I'm also having the same problem with the spinning wheel. Any ideas why the content loads but doesn't display?
Thanks in advance!
I don't think you can change the index.html file type. I believe you would need to link to or reference the index.html, because of the javascript and jquery in the "assets" folder that is create when the HTML5 content is rendered. All of the HTML5 content needs to be hosted in the same folder.
SharePoint Online (cloud-based) is not the same as SharePoint 2013 or SharePoint 2010 (server-based). I was able to upload my published captivate files into 2010 and 2013. Since we moved to SharePoint Online (as part of Office 365) and are no longer using SharePoint server, my files do not open in a browser but open the download file dialog. I cannot run my training courses in our SharePoint environment any longer.
Has anyone found a work around?
