Does anyone know how I can remove bounding boxes from my layers on Elements 11 on a MAC? All of the bounding boxes on my layers are showing on the final product and it's driving me crazy. Thank you.
The bounding box should disappear when clicking the green checkmark e.g. when transforming, scaling, re-sizing etc. If the move tool is selected try switching to another tool e.g. click on the hand tool.
Thank you for the taking the time to reply. I'm probably making a total rookie mistake as it's my first time. I tried your suggestion but it didn't work. I still see the bounding box outlines in my background.
Are you using a layer mask? For example I used the lasso tool to outline the head of the guy on the far left and then pressed Ctrl+J to copy the selection to a new layer. I then dragged with the move tool to position it over the guy in the center – click image below.
Holding down the alt key and clicking to add a layer mask blocks out everything with a black mask. Selecting the brush tool and with the foreground color set to white, I simply brushed over the head to reveal just the face and hat ignoring the outline of the original selection.
You could use the same method for each layer.
You have invested a lot of time on this and it can be salvaged. Fortunately most of the background distractions are linear, and this facilitates correction.
Since you are new to this software, note that the brush cursor size can be increased and decreased with the keyboard bracket keys (] & [) next to the letter P. Also, note that when using the brush tool, click on a start point, press SHIFT, and click an end point. This will produce a straight line.
Try this:
Are you viewing your image at 100% view (actual pixels)?
View>Actual Pixels
Or if you click on the top layer in the layers panel and then
press Shift+Ctrl+Alt+E (windows) or Shift+Cmd+Option+E (mac)
to merge all layers into a new layer, do the lines go away?
You can convert each layer into a smart object and then copy/paste the smart object to your background. The bounding box will no longer be present.
How do you do that in Elements 11 without any externa add-ons?
