• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Is there a way to script options for embed in extendscript?
Enthusiast ,
Mar 26, 2017 Mar 26, 2017
I wrote a javascript to loop through images in a document, embed links and rasterize at a specific resolution. I am treating placedItems and rasterItems the same, and just using app.activeDocument.pageItems[0].rasterize(); which allows for options to be fed to it. RasterizeOptions has a property called "includeLayers" which does not function at all how it sounds like it functions, and always flattens linked files even if they have layers, which I don't think this method supports anyway. Even when true, if an image has opacity or a blending mode, the appearance rasterizes to it, which the manual mentions that this property should maintain these.
What I'm wondering is if there are properties and options I can feed to embed(). Currently, it just goes by the last used settings from the embed dialog, which in some cases I will want to flatten, but others, I will want to convert to layers. Is there an ability to do this through javaacript? I'm beginning to realize I need to learn how to use the SDK so that I can have a full range of functionality.
TOPICS
Scripting
Views
1.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Valorous Hero ,
Mar 27, 2017 Mar 27, 2017
Try to search the preferences file to see if there's some information about this in there. Sometimes options which do not appear in any Illustrator scripting command are actually present in the preferences.
You can try to get this information from the Preference file which is located here on windows:
C:\Users\<UserName>\AppData\Roaming\Adobe\Adobe Illustrator 21 Settings\en_US\x64\Adobe Illustrator Prefs
Open from Recent Documents List with a Script
Votes
Translate
Translate
Report
Report
Enthusiast ,
Mar 29, 2017 Mar 29, 2017
Unfortunately, that file doesn't seem to contain embed settings. Also a bit problematic, because it doesn't save until you close Illustrator, if it crashes, it doesn't record. If it had, I guess I could overwrite those settings, but there still doesn't seem to be anything to feed them back into. If I could overwrite them, I guess that it would just read those, but it's not retained there. Looks like they're storing some other features in other pref files, but I'm not finding embed settings on mac. Any more thoughts are always appreciated!
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Mar 30, 2017 Mar 30, 2017
The preferences file is just to get a look around what they have in there. To read and set the preferences while running the program, you would be using the app.preferences object (which has only a handful of read/write methods).
However, yea I can't find an area speaking of strictly 'embedding'. There are some zones such as PhotoshopFileFormat and TIFFFileFormat which seem to contain not only the export option information but also import option information. I started out looking at the TIFF embed dialog to try and find anything similar and am only led back to the PhotoshopFileFormat zone:
/PhotoshopFileFormat {
  /PreserveSpotColors 0
  /Maximize\ Ediability 1
  /CompoundShapes 1
  /LiveText 1
  /NestedLayers 1
  /WhichProfile 0
  /WriteLayers 1
  /ExportFormat 1
  /ColorModel 1
  /AntiAlias 2
  /CustomDpi 150.0
  /DPI 150.0
  /AI\ Script 0
  /SpotOptionApplyToAll 0
  /SelectedLayerCompName [ 0
  /SelectedLayerCompID -1
  /ShowPreview 0
  /PixelAspectRatio 0
  /HiddenLayers 0
  /ImageMaps 0
  /Slices 0
  /PSD\ Import\ Option 2
Compare to TIFF format:
/TIFFFileFormat {
/Resolution 150.0
/ColorModel 2
/DPI 600.0
/AntiAlias 3
/LZWCompression 0
/ByteOrder 2
It looks as if the Tiff embed options get a boost off the PSD preferences?
To test this, you'll need to determine the syntax with which to set  one of the preferences and observe if this change is reflected in your next UI embed dialog. Then you would need to see if this really holds true for when you set the preference via script and in the very next line call an .embed() method on your placed item.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
LATEST
Notice an interesting discrepancy in their misspelled "Preserve Ediability". This is how the file really reads, but the spelling in the dialog is correct.
Votes
Translate
Translate
Report
Report
