31 Replies Latest reply on Jun 3, 2017 2:45 AM by ThaiBear
    Lightroom CC is slow...
    boaz_m Level 1
      My PC specs are:
      Motherboard: Asus Z170-AR
      Processor: Intel i7-6700K (4.0/4.2 GHz Turbo
      Graphics: EVGA GTX 970 4GB SC
      RAM: 32GB, DDR4, 3000 MHz (2X16GB)
      Operating System: Windows 7, installed on Samsung 840 EVO 250GB SSD
      Catalogs stored on the SSD
      Photos stored on WD Black HDD
      I believe that this is quite powerful PC. However, I still experience slow down when working with Lightroom CC, especially after running it for a few hours. Restarting Lightroom helps for some time but then it slows down again. It is slowing down after merging to HDR for example (in Lightroom). It is also very slow when converting 20-30 files from DNG to JPEG at once. It makes everything slow, until the operation is completed.
      I have configured Lightroom the way I have learned to be the best:
      Use Graphics Processor - Enabled
      I generate 1:1 previews  and keep them for 7 days (Used to be 30 days - No difference)
      Preview quality: Low (It used to be High and the Medium - No difference)
      Standard Preview Size: Auto (1920px) - Same as my monitor size
      The files that I process are DNG, from a 36 MPX camera. Some are standard (50MB) and some are in-camera HDR (150MB)
      Any suggestions to improve the performance? Where do you think my bottleneck is?
        • 1. Re: Lightroom CC is slow...
          Mohit Goyal Adobe Employee (Admin)
          Hi boaz_m,
          Please refer: Optimize Lightroom performance also, are you using any NAS drive for storing images and Lightroom catalog?
          Mohit
          • 2. Re: Lightroom CC is slow...
            F. McLion Adobe Community Professional & MVP
            ... you using any NAS drive for storing images and Lightroom catalog?
            Mohit,
            The catalog can not be stored on a network drive ..
            • 3. Re: Lightroom CC is slow...
              dj_paige Level 9
              Exactly what functions in Lightroom are slow?
              • 4. Re: Lightroom CC is slow...
                boaz_m Level 1
                Thank you all for responding
                Mohit - I have gone through the optimization last many times.... I don't use NAS for storage
                dj_paige - Here is my work flow. I shoot mostly real-estate.
                1. I import the DNG file to Lightroom (most files are around 50mb, some are 150mb
                2. I select the photos that I want to edit, mark them with 3 stars
                3. I do basic editing to each image (colors, light, adjustment brush etc.)
                4. Sometime I also merge to HDR. This consumes a lot of resources and after the merging is done, Lightroom will slow down significantly, until I restart it. Even going through the photos becomes a hassle.
                5. Most images don't require blanding so at this point I convert them to JPEG, and reduce the size to 4672 pixels. This, again, takes time (I didn't measure) and takes resources from the computer (CPU? GPU? RAM?)
                6. Some images require blanding in photoshop. A few sets of 2-4 images. I open them as layers in photoshop and save them to TIFF. This creates some 1GB files. I then convert them to JPEG and delete the TIFF
                7. After processing this way a couple of folders, with 20-30 images each, Lightroom slows down dramatically and I need to restart it, What slows down? Pretty much everything. Going through the images, editing some more. I often see a white screen for a few seconds, especially while Lightroom is converting about 10-20 files to Jpeg. But also after this task is completed, then re-editing some of the images can be really slow.
                When I look at the task manager, I see that Lightroom uses up to 3GB of RAM. Photoshop may be using 1GB and the browsers maybe 1GB together. So if I have 32GB then RAM shouldn't be a problem, right?
                So what is the bottleneck here? CPU? GPU? Me....??
                • 5. Re: Lightroom CC is slow...
                  dj_paige Level 9
                  So it would help if you talked in megapixels and not megabytes. What is the size of your images in megapixels? Ok, I see you said 36 megapixel photos, these are relatively large photos, which will require lots of CPU speed (and GPU if enabled).
                  This could be the problem. Using large amounts of brushing is known to slow Lightroom down. You have all the symptoms of the problem caused by lots of brushing.
                  I guess this step doesn't seem necessary to me (and I also don't recognize the word "blanding"), and in my mind, this entire step is an unnecessary waste of time. However, anticipating that you have a valid explanation for why this is needed, the speed of converting to a JPG is entirely based on the CPU, and as I said, if you did a lot of brushing, it will take a lot of time.
                  Brushing! It slows Lightroom down. If you are doing a lot of brushing in Lightroom, this is most likely the problem.
                  Instead of doing lots of brushing in Lightroom, do it in Photoshop; or if you must do it in Lightroom, turn off the GPU acceleration (Preferences->Performance->uncheck "use graphics processor"), do the brushing before you turn on the lens corrections and transforms, and if possible, get a faster CPU.
                  • 6. Re: Lightroom CC is slow...
                    boaz_m Level 1
                    1. I didn't realize that brushing slows down Lightroom. I find it to be one of the most useful features in Lightroom editing..
                    2. Sorry, I meant "blending" and not "Blanding".. I used to open the DNG files in Photoshop, then edit and save them as TIFF (16 bit) and then convert them to JPEG so that I can deliver them to clients. But I found that opening 10-20 images at the same time works better if they are JPEG. But then I lose time by converting them all from DNG to JPEG. Converting from TIFF to JPEG seems to be working much faster and consumes less resources from my computer
                    3. Brushing in Lightroom is a lot easier than in Photoshop. I am assuming that you mean by applying the changes in layers and masking them out? How does turning off GPU help with brushing? Should I do ALL Lightroom editing BEFORE lens correction and transform?
                    4. Faster CPU? Is 4.2 not fast enough..?? What would you recommend? Is better GPU going to help at all? It is just easier for me to replace than a CPU
                    Thanks for all the help so far!
                    • 7. Re: Lightroom CC is slow...
                      BobRockefeller Level 1
                      How is the external hard rive connected? USB-3? Something else?
                      • 8. Re: Lightroom CC is slow...
                        boaz_m Level 1
                        What do you mean? The HDD is not external. I store the images on internal HDD and the operating system & catalogs on SSD
                        • 9. Re: Lightroom CC is slow...
                          Oh, OK. That should be fine.
                          • 10. Re: Lightroom CC is slow...
                            dj_paige Level 9
                            3. Brushing is a lot easier in LR, but a lot faster in Photoshop! In Photoshop, the order of editing doesn't matter, as far as I know. In Lightroom, the speed of editing will be faster if you do the brushing without lens corrections and transforms, and then when you are done with the brushing, turn on lens corrections and transforms. Also turn off the GPU acceleration if it is on.
                            4. Sadly, this entire problem is due to the way LR is programmed, and a faster CPU will help. Whether or not you want to pay for a faster CPU, compared to changing your workflow, is up to you. A GPU will not help with the brushing issue.
                            • 11. Re: Lightroom CC is slow...
                              D Fosse Adobe Community Professional & MVP
                              Honestly, is an i7 6700 slow? How much faster should it be?
                              If any pattern is discernible in this, it's that the higher the machine specs, the greater the likelihood of speed issues.
                              These suggestions to upgrade the CPU should stop. It's obviously not where the problem is. It will not get anyone anywhere, except maybe an unnecessary expense.
                              • 12. Re: Lightroom CC is slow...
                                I agree. That CPU is quite powerful and should not be a problem. I run an iMac 5K with a 4 GHz i7 and find Lightroom plenty responsive.
                                But I don't use many, many brush adjustments. Maybe a couple or four. How many is "a lot?" How many is a problem?
                                • 13. Re: Lightroom CC is slow...
                                  dj_paige Level 9
                                  The problem could be Lightroom, but a faster CPU will chug through the tasks faster than a slower CPU.
                                  • 14. Re: Lightroom CC is slow...
                                    Of course. But how much faster than an i7 at 4 GHz is common?
                                    • 15. Re: Lightroom CC is slow...
                                      I don't think so, because the real problem is elsewhere. Not even the six-year old i5 that I use at home, ever peaks CPU usage, whatever I throw at it. And what I mostly throw at it is 36MP D800 files.
                                      My work machine, an i7 that should be at least twice as fast, is - well, not. If anything, it's a bit slower. Everything else is identically set up (it has to be for a number of reasons), including a single 1920 x 1200 display.
                                      It's not the CPU.
                                      • 16. Re: Lightroom CC is slow...
                                        dj_paige Level 9
                                        It's not the CPU.
                                        It may be that the real problem is elsewhere, that there is some problem with the coding in Lightroom, no one has been able to identify or prove that this is the case.
                                        The user is doing a lot of brushing, which is computationally intensive. The user has 36 megapixel originals which adds to the amount of computations that have to be done. I don't remember what size monitor he is using, but if he is using a 4K or larger monitor, that increases the amount of computations that have to be done. To deny that a faster CPU could do these calculations faster is not something I can agree with.
                                        • 17. Re: Lightroom CC is slow...
                                          Is there any evidence that the CPU is maxed out? Perhaps Lightroom is not CPU bound, in this case?
                                          • 18. Re: Lightroom CC is slow...
                                            boaz_m Level 1
                                            So turning off GPU at what point? After brushing and before lens correction? Or turn it off completely? What is the logic behind this action?
                                            The CPU that I use is Intel i7-6700k and according to a bench test that I have read, only the Intel i7-7700k was faster, and by no more than 2-4% so I guess I will skip this for now..
                                            • 19. Re: Lightroom CC is slow...
                                              boaz_m Level 1
                                              I am using two 24" monitors, 1920X1200
                                              I will stars working as dj_paige suggested, brushing before lens correction and see how it helps
                                              • 20. Re: Lightroom CC is slow...
                                                dj_paige Level 9
                                                I have never had to decide when to turn the GPU acceleration on or off, because I do not use GPU acceleration with my Lightroom. So, I leave it up to you to experiment with this, but I do know that GPU acceleration OFF will speed up brushing (as stated by Eric Chan, the LR developer in charge of programming, that's probably not his actual title but you get the idea)
                                                • 21. Re: Lightroom CC is slow...
                                                  boaz_m Level 1
                                                  See task manager below
                                                  • 22. Re: Lightroom CC is slow...
                                                    Bob Somrak Level 5
                                                    You could close all the programs running except Lightroom and see how it works.  I'm using that same processor on a 27 inch iMac retina with 16gb RAM with the catalog, photos and previews on and external thunderbolt Lacie SSD and it works fine.  I usually have Safari and Mail loaded and occasionally Photoshop but close Photoshop when not needed.
                                                    • 23. Re: Lightroom CC is slow...
                                                      boaz_m Level 1
                                                      What size photos are you working with?
                                                      • 24. Re: Lightroom CC is slow...
                                                        Bob Somrak Level 5
                                                        Mine are 24mp cr2 files but a friend of mine edits his 36mp Nikon files on my computer and he has not complained about the speed.   Did you try the editing with everything closed except Lightroom to see how it works?
                                                        • 25. Re: Lightroom CC is slow...
                                                          boaz_m Level 1
                                                          No. I assumed that Internet browsers consume mostly RAM and not CPU or GPU, and since I have 32GB I thought it was plenty to handle all  - Lightroom, Photoshop, Chrome and Firefox
                                                          • 26. Re: Lightroom CC is slow...
                                                            Jao vdL Adobe Community Professional & MVP
                                                            A possible cause for Lightroom slowdowns is malware detectors and antivirus software including Microsoft's malware detection software. Some rescan your entire catalog file every time a single change gets written to it. Trick is to exclude the catalog file and preview database from those scanners. Don't know if this is your problem but it's worth a try.
                                                            • 27. Re: Lightroom CC is slow...
                                                              boaz_m Level 1
                                                              I have already tried. It is not the case..
                                                              • 28. Re: Lightroom CC is slow...
        boaz_m Level 1
        Thank you all for your advices.
        One thing that seems to be improved a lot is exporting DNG to JPEG speed, after disabling GPU. This was very helpful. Thanks
        • 29. Re: Lightroom CC is slow...
        Frank Nadeau Level 1
        Same story here.
        I have dual XEON with 8 cores each. 96 GIG of ram. OS on a single SSD (and assigned Adobe CACHE there), Database of lightroom on a separate PCIe Memory storage (more 12GB/s of transfer). All the images are on a 12x3TB SAS RAID5 Storage (for fast ready access). And dual GTX 1080 Video card. Editing only on 1440P on my screen.
        I'm able to edit 4K DCI video content at 60pfs live on my system, but I'm not able to edit a shooting of 200 RAW pictures without having to wait and wait and wait to lightroom to came alive.
        I have monitored CPU, Hard drive access, memory access, and nothing even get 25% of the system resources.
        I have build and tweak my system to get better performance on Lightroom,Bbut now I really suspecting huge mistake in the code. I already saw (and this is history for Adobe) huge memory leak when using it. But even there this is not a problem, because have have plenty of RAM. I have even try to start with fresh Lightroom data without any sucess.
        It is now slow as some time, image remain stock, even if we are switching to another one.
        Very hope Adobe will fix this problem.
        Frank
        • 30. Re: Lightroom CC is slow...
        dj_paige Level 9
        For some reason, dual Xeon CPUs have been reported to be slow; and furthermore somewhere in the forums a solution has been posted. I suggest you search for it.
        • 31. Re: Lightroom CC is slow...
        ThaiBear Level 1
        Fixed!
        I wish I could find the all the places I have posted about Lightroom on large files and 4k being unusable.  I bought a couple of new camera bodies that are 30meg and 50 meg pixel sensors and have started shooting a lot of 4k video.  I could see that Lightroom was slower with the larger files (some 60megs), but I wanted to see the increase in clarity that I thought I should see.  So I bought a couple of 4k  (4096x2160), 99.9% adobe 1998 screens with 2 Nvidia 1070's.  My machine was a I7 2790 4 core with 32 megs of ram.    Although Photoshop showed me detail that I had never seen before on my HD monitors, LIghtroom became all but unusable. 3 seconds to spot heal or load a new picture. So many times, the screen would just blank for a couple of seconds.  It was very frustrating.  I was loading full size previews and using the GPU.  I tried various changes in the setup, turning off the GPU, increasing cache, and decreasing the preview size.  All had minor effects and I just had to alter my work flow to avoid LIghtroom.... until:
        I just completed another upgrade to my machine.  A new MSI G.L.G. 2011-3, x99a motherboard with an i7 6950x 10 core processor and 128megs of 3000hz DDR4.
        I still have medium previews selected, now with 8gb of cache on an SSD.  I have the GPU selected and I'm using SLI on the two Nvidia 1070's.
        So I have made a bunch of changes, and I can't be sure which are helping, but Lighroom is back to enjoyable to use as a great tool to process many photographs.  It's as if I turned back the clock to a 12 megapixel camera, HD video and HD screen resolution.
        Still to say, that it does seem as if Lightroom needs a refresh to be 4k compatible at a lower cost to the user. 4k is here and the level of detail is such a great tool to grade and edit photo's and video it has become necessary.
        Win 10.0.14393
        3 LG IPS LED 31MU97C monitors (4096x2160/60hz each)
        2 NVidia 1070's / SLI
        128gigs Corsair DDR4 3000mhz
        MSI X99A G.L.G. Carbon
