1 Reply Latest reply on Sep 26, 2017 12:59 AM by alam_84
    set the timeout for indesign server?
    Brahnavan Level 1
      I have a send a SOAP request to an inDesign Server on MAC. When running larger jobs, the server is not terminated for the given timeout instead it throws exception after long time. I believe that the server is still running in the background producing the outputs.
      The job set to 30 sec timeout and , this is the time line of the job starts and ended
      begin : 16:30:53
      Start job ...
      java.net.SocketTimeoutException: Read timed out
      Fail job...
      14 minutes, 44 seconds.
      End : 16:45:37
      it almost took around 14 minutes, 44 seconds. to terminate the job.
      the code snippt of the set timeout
      Service inddService = new ServiceLocator();
      ServiceStub ids = (ServiceStub) inddService.getService(new URL(url));
      ids.setTimeout(30000);
      Brahna
        • 1. Re: set the timeout for indesign server?
          alam_84 Level 1
          Hi Brahna,
          Are you facing timeout issue for large jobs in InDesignServer CC2017?
          In my workflow earlier we were using CC2015 and it processed large document in 4 hrs and there was no timeout happen and if I just replaced CC2015 with CC2017 then for same document a timeout happen after 10 mins.
          Is there any change related to timeout b/w CC2015 and CC2017.
          Also Is there any place where we can get the server sdk for CC2017 as prerelease site does not have it.?
          Regards,
          Alam
