3 Replies Latest reply on Mar 27, 2017 11:22 AM by Betude
    On import CR2 look changes
    Betude Level 1
      I shoot with a flat profile for my still and on import Adobe Lightroom changes the look of my photo. Adds much more contrast than what the original looks like when shot. Is there a way to change this?
      See the before and after photos.
        • 1. Re: On import CR2 look changes
          joefry99 Adobe Community Professional
          I'm not sure what actions have taken place between your before and after pictures here, but my first suspicion is to double-check the film profile being applied under Camera Calibration to see if that might be causing the discrepancy.
          • 2. Re: On import CR2 look changes
            It doesn't matter what profile you use to take the image. With Lightroom, there are default settings that are applied  every time you import new images. If you want a flat profile look then you need to modify a newly imported image so that it looks the way you want it to look on import. Then create new camera defaults using those settings.
            Lightroom does not read camera-selected profiles. You can choose from different profiles in the Calibration  section.
            • 3. Re: On import CR2 look changes
              Betude Level 1
              I see, I didn't know this. Thanks for the heads up. I'll try and create a camera default that matches.
