I've been having a ton of issues lately, now it is at the point of unusable. I have a great deal of time and effort invested in Lightroom/Photoshop but tbh the problems have become way to frequent. every update there are issues. . I'm using a Dell 13" i 5378 all drivers are updated, gpu is disabled all files being stored on outboard drives . If I can't resolve this i will be switching software platforms i have deadlines due for publication this week and editing on LR mobile is not an option
Processor | Intel Core i5-7200U 2.50 GHz with Turbo Boost Technology up to 3.10 GHz |
Memory | 8GB DDR4 2400 MHz |
Hard drive size | 1TB 5400 RPM HDD |
Operating system | Windows 10 Home, 64-bit |
PC type | 2 in 1 |
Optical drive | None |
Media drive | SD card reader |
Audio | Waves MaxxAudio Pro |
Video | Intel HD Graphics 620 with shared graphics memory |
Ports | 2 USB 3.0 • 1 USB 2.0 • 1 HDMI • Headphone output/Microphone input combo |
Battery | 3-cell 42WHr* |
Camera | Integrated webcam |
Wireless | 802.11ac (Miracast enabled) |
Bluetooth | Bluetooth 4.0 |
Hi eddiesmithphoto,
Could you please take a look at this linked article Adobe Lightroom GPU Troubleshooting and FAQ and let us know if the steps mentioned help.
Akash
thanks i did all that, the computer is at this point less than 5 months old. all drivers are up to date, GPU disabled. booted ok wouldnt import just blanked and stopped responding.
it's not the most sophisticated computer but there is no reason it should not have support at this point. If a resolution cannot be found I will be leaving adobe after more than a decade
We'll ensure your issue is dealt with priority and resolved as soon as possible. May I know the source of import? Is it a camera card or external drive? Have you tried importing from desktop instead after removing all external devices from your PC?
Akash
Import from built in SD card , it goes to an external 4tb driv, all my photos are on external drives and backed up on same. Nothing is imported to or on built in drive
I can transfer files and try importing as soon as I'm back to that unit.
Thanks, I am waiting for your reply.
Regards,
Akash
copied the files to a folder on my desktop from two cards i now am a week late processing files for (and have likely lost future work with the magazine ) still wont import , try and select c to import from to the drive everything els is on (and have disconnecxted all other drives) , this is only last update this really started with. I cant even just add the folder from the drive (which is a horrible solution for almost anyone given most people will be running smaller SSD drives and using external for data)
Next suggestion please
Using external drivers with Lightroom is perfectly fine.
Could you please post the Lightroom Help>>System info report here?
Akash
as i mentioned previously they did not help. I have at this point uninstalled and re-installed and started the catalogue over from scratch. 129k photos you could understand why i did not want to do this. I am able to work though since previews aren't built it takes me almost 15 minutes before i can get started while it loads. All i can think is the catalog file was somehow corrupted because though tediously slow i can do the work eventually (and i am ordering a new desktop that will be faster to be my main unit and the laptop will revert to travel)
