2 Replies Latest reply on Mar 31, 2017 2:43 AM by stevenc43
    Changing shape properties after being created via pathItems in script
    stevenc43
      I have a script which creates rectangles, rounded rectangles, ellipses and polygons using pathItems. However, when I open the transform menu it says 'no shape properties'. Can I not, for example, change the number of sides of a polygon via the transform menu if I create a polygon in this manner?
        • 1. Re: Changing shape properties after being created via pathItems in script
          moluapple Level 4
          The answer is yes, script do the jobs in old style, the objects script created are PathItems, not Shapes.
          A solution can be record an action and call it in script. Here is a example:
          String.prototype.formatUnicorn = function () {
              "use strict";
              var str = this.toString();
              if (arguments.length) {
                  var t = typeof arguments[0];
                  var key;
                  var args = ("string" === t || "number" === t) ?
                      Array.prototype.slice.call(arguments)
                      : arguments[0];
                  for (key in args) {
                      str = str.replace(new RegExp("\\{" + key + "\\}", "gi"), args[key]);
              return str;
          function drawArc(p) {
              var w = h = addZero(2 * p.r),
                  x = addZero(p.x),
                  y = addZero(p.y),
                  s = addZero(p.s),
                  e = addZero(p.e);
              var actionStr = [
                      '/version 3',
                      '/name [ 3',
                      ' 736574',
                      '/actionCount 1',
                      '/action-1 {',
                      ' /name [ 6',
                      '   616374696f6e',
                      ' /eventCount 3',
                      ' /event-1 {',
                      '   /internalName (ai_plugin_ovalTool)',
                      '   /hasDialog 1',
                      '   /showDialog 0',
                      '   /parameterCount 7',
                      '   /parameter-1 {',
                      '     /key 1953460076',
                      '     /type (integer)',
                      '     /value 14',
                      '   /parameter-2 {',
                      '     /key 2003072104',
                      '     /type (unit real)',
                      '     /value {w}',
                      '     /unit 592476268',
                      '   /parameter-3 {',
                      '     /key 1751607412',
                      '     /value {h}',
                      '     /unit 592476268',
                      '   /parameter-4 {',
                      '     /key 1668182644',
                      '     /type (boolean)',
                      '     /value 0',
                      '   /parameter-5 {',
                      '     /key 1668183128',
                      '     /value {x}',
                      '     /unit 592476268',
                      '   /parameter-6 {',
                      '     /key 1668183129',
                      '     /value {y}',
                      '     /unit 592476268',
                      '   /parameter-7 {',
                      '     /key 1667854947',
                      '     /type (boolean)',
                      '     /value 0',
                      ' /event-2 {',
                      '   /internalName (ai_liveshape_ellipse)',
                      '   /parameterCount 3',
                      '   /parameter-1 {',
                      '     /key 1936220528',
                      '     /type (enumerated)',
                      '     /name [ 0',
                      '     /value 9',
                      '   /parameter-2 {',
                      '     /key 1954115685',
                      '     /name [ 0',
                      '     /value 10',
                      '   /parameter-3 {',
                      '     /key 1885950836',
                      '     /value {s}',
                      '     /unit 591490663',
                      ' /event-3 {',
                      '   /parameter-1 {',
                      '     /key 1936220528',
                      '     /name [ 0',
                      '     /value 9',
                      '   /parameter-2 {',
                      '     /key 1954115685',
                      '     /name [ 0',
                      '     /value 11',
                      '   /parameter-3 {',
                      '     /key 1885947246',
                      '     /value {e}',
                      '     /unit 591490663',
                  ].join('\n')
                  .formatUnicorn({w:w, h:h, x:x, y:y, s:s, e:e});
              createAction(actionStr, 'set');
              app.doScript('action', 'set');
              app.unloadAction('set', '');
          function addZero(n) {
              return (n + '.0').replace(/(\.\d*)(\.?0?)$/, '$1')
          function createAction(str, set) {
              var f = File(set + '.aia');
              f.open('w');
              f.write(str);
              f.close();
              app.loadAction(f);
              f.remove();
          drawArc({
              x:100,
              y:100,
              r:50,
              s:60,
              e:120
          2 people found this helpful
          • 2. Re: Changing shape properties after being created via pathItems in script
            stevenc43 Level 1
            Great! Worked like a charm! I recorded all shape actions, exported the code and used yours as a template to recreate all! Much appreciated.
